When I press the power button, regardless of type of energy input, the check, AC, GAS, and Auto light are all on and the fridge will not cool. The mode and temp buttons will not work.
First thing, disconnect AC and DC power. You can leave the LP attached but go ahead and close the valve for now.
Plug in AC only and let it boot up. If the fridge does not automatically, press the power button to turn it on. The refrigerator should start working. Let it run for a while to make sure it does get cold. Once you confirm it does work you can either unplug the fridge or just open the breaker in the fuse panel.
Before you reconnect the DC wires, you need to check the power coming in. Most camper units will have wiring that will have color on one side and white on the other. The color wire will be your 12VDC, white is neutral return. Once verified, pull out the fuse for the power to the fridge to isolate the DC voltage. Check with the manual for the fridge, the positive input should be marked or identified in some manner. Open the valve to let LP back into the lines and wait a few minutes. Plug the fuse back in. If the fridge does not turn on automatically, press the power button to turn it on.
With the DC power on and no AC detected, the display should display CHECK. Let the fridge run for a bit to make sure it cools. Once you know it is working, the breaker for the AC can be closed to turn on the AC power to the fridge. Press the MODE button until AUTO displays displays.
Let it get cold and resume normal operations.
OPERATING MODES
AUTO MODE
Press the AUTO/MANUAL mode selector button (2) to the DOWN position. The AUTO mode indicator lamp (A) will illuminate.
When operating in the AUTO mode, the AUTO mode indicator lamp (A) will illuminate. The control system will automatically select between AC and GAS operation with AC having priority over GAS. If the control system is operating on AC energy and it then becomes unavailable, the system will automatically switch to
GAS. As soon as AC becomes available again the control will switch back to AC operation.
If 120 volts AC is not available, the control system will automatically switch to GAS operation. Within 45 seconds the burner should be ignited and operating normally. If unsuccessful, the CHECK indicator lamp (B) will illuminate.
To restart an ignition attempt with the CHECK lamp illuminated or to clear (turn off) the CHECK lamp, press the main power ON/OFF button to the OFF and then to the ON position. The control system will attempt a new 45 second ignition sequence.
On the initial refrigerator start-up on gas (120 volts AC is not available), it may take longer than 45 seconds to allow air to be purged from the gas line. If the refrigerator has not been used for a long time or the LP tanks have just been refilled, air may be trapped in the supply lines. To purge the air from the lines may require resetting the main power ON/OFF button (1) three of four times. If repeated attempts fail to start the LP gas operation, check to make sure that the LP gas supply tanks are not empty and all manual shutoff valves in the lines are open.
NOTE: DO NOT continue to reset GAS operation if the CHECK indicator lamp continues to be illuminated after 3 or 4 tries.
If 120 volts AC becomes available while the CHECK indicator lamp is on, the control system will switch to 120 volt AC operation, The CHECK lamp will not turn off until the main power ON/OFF button is pressed to the OFF then ON position.
In AUTO mode operation, the temperature is controlled by a single temperature setting.
MANUAL MODE
When operating in the MANUAL mode, the AUTO mode indicator lamp (A) will be off, and the refrigerator will run continuously on the energy source selected by the control system.
NOTE: The food in the lower compartment may be frozen if the refrigerator is left on "MANUAL" mode.
STANDBY MODE . .
This control system contains a feature that will continue to operate the cooling system in the event of a failure of a major operating component. If the control cannot read the temperature sensor and operate at the preset temperature, then the control will run the cooling unit like the MANUAL mode.The refrigerator will continue to operate in this mode indefinitely or until a new sensor is installed and the
system is reset.
I posted the above information from the contents of the service manual. I can help you but... at the moment for sure I have come to the conclusion that ONE of the lights your seeing is the CHECK light. The mystery is... what is the 2nd light your seeing? Manual of Stand-by?
I am pretty sure we can sort this out but... we need to really communicate clearly and well. In our posts here.
Thanks for choosing FixYa,
Kelly
