20 Most Recent
Atwood 6 Cubic Ft RV Refrigerator Black Acrylic Panel Set Questions & Answers
It will not turn on.
First thing, disconnect AC and DC power. You can leave the LP attached but go ahead and close the valve for now.
Plug in AC only and let it boot up. If the fridge does not automatically, press the power button to turn it on. The refrigerator should start working. Let it run for a while to make sure it does get cold. Once you confirm it does work you can either unplug the fridge or just open the breaker in the fuse panel.
Before you reconnect the DC wires, you need to check the power coming in. Most camper units will have wiring that will have color on one side and white on the other. The color wire will be your 12VDC, white is neutral return. Once verified, pull out the fuse for the power to the fridge to isolate the DC voltage. Check with the manual for the fridge, the positive input should be marked or identified in some manner. Open the valve to let LP back into the lines and wait a few minutes. Plug the fuse back in. If the fridge does not turn on automatically, press the power button to turn it on.
With the DC power on and no AC detected, the display should display CHECK. Let the fridge run for a bit to make sure it cools. Once you know it is working, the breaker for the AC can be closed to turn on the AC power to the fridge. Press the MODE button until AUTO displays displays.
Let it get cold and resume normal operations.
What's an example of a passive form of solar energy?
Passive solar energy can be used to keep buildings warm. Some buildings have large windows on the side of the building the sun hits. The sun's ray go through the windows and penetrate the heat-absorbent floors and walls. At night, this heat is released into the building.
What are the probles when using solar energy sourse
Not using enough solar panels or total output to match the needs for what you would be using it for. Small solar panels (35-100 watt) are great just to keep 1-4 batteries charged when not in use but if you plan to be running an inverter and powering appliances, living quarters in an RV or larger scale living, that if when you would need A LOT of solar panel and a basement full of batteries to use at all times. A lot of money would be spent on the panels and batteries but if you do not have the right equipment to control the electricity and monitor everything, you may be better if donating the money to a good charity where it will be much more useful and greatly appreciated
Can I buy wind turbine generators on Amazon?
You can buy wind turbine generators from Amazon here: http://www.amazon.com/s/ref=nb_sb_sabc?url=search-alias%3Daps&pageMinusResults=1&suo=1367394691758#/ref=nb_sb_ss_i_0_14?url=search-alias%3Daps&field-keywords=wind%20turbine%20generator&sprefix=wind+turbine+g%2Caps%2C256&rh=i%3Aaps%2Ck%3Awind%20turbine%20generator&sepatfbtf=true&tc=1367394695955
How do you make a solar oven?
I just found this on the Home Science Tools site. The instructions here are for kids, but they do say they will need an adult's help, so I hope it's what you were looking for:http://www.hometrainingtools.com/build-a-solar-oven-project/a/1237/
Who first used solar energy?
Edmund Becquerel first hypothesized that light could be turned to energy in 1838, but the first solar powered motor was made by Auguste Mouchout in France a few decades later
