Furniture Logo
M
Megan Pedemonti Posted on May 01, 2016
Wine fridge - Furniture
David Parker
Level 1:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Contributor 12 Answers
  • Posted on Jun 12, 2016
David Parker
Contributor
Level 1:
Passionate:
Habit-Forming:
Answers
12
Questions
0
Helped
13131
Points
54
Really depends on how much you want to store and where you want to put it. Check out this guide: www.vinocoolers.com
Avanti wc1500dss wine chiller not getting cold but does the opposite gets hot
https://manualsdump.com/en/manuals/avanti-wc1500dss/66172/12
The above has a troubleshooting matrix.
Power supply: Check if the wine fridge is receiving power from the mains supply. If it's not, there might be a major issue with the mains power or the PSU circuit board in the product that'll likely need replacing if it's faulty.
Condenser fan: The condenser fan is designed to cool the condenser and condenser coil within the Avanti wine cooler. If it doesn't function, the condenser and coil can overheat - causing the internal area of the wine fridge to heat up too. Take a look at the rear of the unit and make sure the condenser fan is spinning freely and not blocked (by dust / dirt) or making excessive noise due debris or a blockage.
Thermostat: If the Avanti wine fridge thermostat is working correctly, it's responsible for making the condenser, evaporator, fan, and compressor work - so it's super important! The thermostat also allows you to control and adjust the temperature of the wine cooler so if the reading on thermostat is inaccurate (or flat out wrong) the wine cooler temperature will likely be inaccurate too.
Why Is My Avanti Wine Fridge Not Cooling (And How To Fix It) - Expert Wine Storage
1helpful
What does E6 code in Frigidaire wine fridge mean? Model FGWC5233TS
The E6 error code on a Frigidaire wine fridge, specifically the model FGWC5233TS, indicates a fault with the upper temperature sensor. When this error code is displayed, it means that the temperature sensor located in the upper portion of the wine fridge is not functioning properly or is experiencing a malfunction.
To troubleshoot and resolve the E6 error code, you can try the following steps:
  1. Unplug the wine fridge from the power source for a few minutes and then plug it back in. This may reset the error code and resolve any temporary issues.
  2. Ensure that the wine fridge is properly leveled. Uneven positioning can affect the performance of the temperature sensor. Adjust the feet or placement of the unit to ensure it is level.
  3. Check for any obstructions or blockages around the upper temperature sensor. Make sure there are no items blocking the sensor or disrupting its operation.
  4. If the error persists, it is recommended to contact Frigidaire customer support or a qualified appliance technician for further assistance. They can provide specific guidance based on the model and help diagnose and repair the issue with the upper temperature sensor.
1helpful
U-Line ULN-15WCSS-00 Built In Wine Storage Refrigerator. How to remove and replace wine racks in ULN-15WCSS-00 please.
Question edited for clarity, maker.
Question moved from Watches to U-Line Wine Fridge.
They are usually an expanding plug. You push it to the hole and press the central pin. If you can grip it with pliers, you can pull it out. The other way is to use a nail punch and push the pin all the way through, pull out the support and retrieve the pin from the insulated cavity.
https://www.amazon.ca/s?k=U-Line+wine+fridge+shelf+support&i=tools&crid=6P110ETE4YHD&sprefix=u-line+wine+fridge+shelf+support%2Ctools%2C69&ref=nb_sb_noss
https://www.google.com/search?q=u-line+wine+fridge+shelf+supports
My Wine Enthusiast fridge stop working, the front panel is blinking.
Question edited for typo.
Question moved from Furniture to one of the Wine Enthusiast categories.
Try a Power Reset. Disconnect from the wall plug. Wait 5 minutes and plug back in. If that doesn't fix it, you need a service call. They have a history for control board failure.
Page 6 in this manual says it is indicating accessibility to settings.
http://static.appliancesconnection.com/attachments/D569d6dc555d6e.pdf
More here, including videos
https://www.google.com/search?q=wine+enthusiast+n%27finity+pro+wine+fridge+control+panel+blinking
1helpful
2answers
Premium appliance wine fridge model bwc600 fault code E4
This error message means that there is a problem with the fan connection in the unit.
Where can we get info relating to wine fridges?
use google and enter " wine fridges "
Nov 30, 2016 • Furniture
I have barely any space for a wine cooler and need a narrow fridge. Can anyone recommend a narrow cooling fridge for me - preferably something thermoelectric?
Without knowing the amount of space you have to put the cooler, it is difficult to find you one that will fit. What I did though was find a great site with a few brands of slim wine coolers. Look through and maybe they will have something for you.
http://www.winecoolerexpert.com/slim-wine-cooler-refrigerators.html
Jul 31, 2012 • Furniture
Other than temperature, is there any other reason not to store wines in a regular fridge? I don't mind my wines being slightly cooler and I can always leave them on the counter for 10 minutes bef
Aside from temperature, humidity is a major concern. The low humidity levels can cause the cork to dry/shrink allowing room for both air and other food odors to enter the bottle and tamper with the quality of the wine inside. Wine coolers offer an optimal humidity level of 50-80% needed to keep your wine in good condition.
5helpful
Wine fridge stopped cooling. Just clicks every
its the ptc relay go to repairclinic.com...type in model #...its a cheap and easy fix.if you see what the part looks like on line youll find it on cooler.should be left of compressor behind black plastic cover with 1 screw
Wine fridge light does not turn off
You may know this already, but for what its worth. There is a small switch on the bottom vent grill for on/off of light. Check there first.....
Top Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Furniture Expert? Answer questions, earn points and help others
