20 Most Recent Magic Chef MCWC30MCG Compact Wine Cooler Questions & Answers
2answers
Can't figure out how to
Hello there,
How many techies does it take to change a light bulb (without a hammer)?
There is a tiny screw holding the lens cover in place. Once removed, the lens will come off and you can access the bulb.
Hope this helped
Thanks for using FixYa
Mike
4/17/2024 9:48:29 PM • Magic Chef... • Answered on Apr 17, 2024
E3 error message on Magic Chef wine cooler
Taken from another poster at Home Depot reviews and similiar to what others have found...
The e3/e4 problem is the "connectors" for the fans to the middle separator shelf are put in the pathway of condensation. This causes them to get wet and rust. PLEASE NOTE: If you decide to attempt this fix, you take full responsibility for your fridge and the outcome. If you don’t think you can do this…DON’T! Call a licensed electrician. Here is how I resolved my e3 issue: 1) Unplug the fridge
2) Remove all wine and the metal shelves
3) Remove the 2 screws from the middle separator shelf, one on each side on top
4) Remove the 4 screws from the backboard, one in each corner
5) Slide out the middle shelf slowly, on the right hand side towards the front of the shelf there will be 4 connectors you must disconnect before removing the shelf (they are tucked into the shelf). With one hand on the backboard and one on the shelf, slowly take them out together
6) Once you have the backboard and shelf out, you'll see there is a black and white connector, each having a red and black wire on each side
7) These are the fan connectors that are causing the issue. Mine were brown/green and damp (not good for electricity)
8) Using wire cutters, cut as close as possible to the "black" connector on each side to remove it. You will have 4 wires left, 2 from the backboard and two from the shelf (both having a red and black)
9) Take some of the sheath (cover) off of each wire
10) Take the red wire from the backboard and the red wire from the shelf and twist the metal portion together
11) Cover w/ electrical tape!!! Or you will have the same e3/e4 issue
12) Repeat step 10 and 11 for the black wires
13) Move onto the "white" connector and repeat steps 8 - 12
14) Put the backboard and shelf back in the fridge. Be careful not to pull the backboard and shelf apart or your connection may come apart
15) As you slide the shelf in, make sure the wires you disconnected in step 5 are in the "channel" on the side of the shelf or the shelf won't slide properly.
16) Reattached the 4 connectors and then re-attach the backboard and the shelf with the screws
17) Plug the fridge back in
18) Put the metal shelves and wine back in
" Sucks that a $0.10 piece of heatshrink on the connectors could avoid this...? Bad Design.
7/18/2020 12:26:42 AM • Magic Chef... • Answered on Jul 18, 2020
3answers
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
4/24/2020 2:01:59 AM • Magic Chef... • Answered on Apr 24, 2020
0answers
0answers
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence. Either that or the opposite effect is doing it. The answer might be to find a 61 degree place in your house to keep the reds.
4/28/2017 7:36:09 PM • Magic Chef... • Answered on Apr 28, 2017
How do you change the light bulb in the e wave wine cooler?
I took the screw out but the lens won't budge and I don't want to break it. how does the lens come out?
11/6/2016 6:24:21 PM • Magic Chef... • Answered on Nov 06, 2016
2answers
I have a Magic Chef beverage cooler, MCBC580DBT, that the compressor only starts when I bang on the side
Hi Bob, did you ever get an answer to your question? I have the same problem. Thank you,
4/22/2016 6:51:43 PM • Magic Chef... • Answered on Apr 22, 2016
12answers
Magic Chef MCWC44DZ E4 error
I found the connectors corroded for both fans. The lower fan connector had one pin that was completely destroyed. I hard wired the wires together as a test and the unit is working perfect. Check the fan connectors by removing the two screws that hold the shelf in place and cafefully slide out fron the cooler. You will have to disconnect several connectors hidden in the right side of the shelf before you can completely remove it. Good Luck.
11/16/2015 2:38:40 PM • Magic Chef... • Answered on Nov 16, 2015
I have a MagicChef wine cooler that stopped working. Compressor and fan do not run although there is power to the unit since the light turns on. Compressor is hot to the touch.
your unit needs to have a new capacitor possibly. However, it will be next to impossible to find someone who will check it out and get the right one for this unit. Unless the unit is under warranty, I would suggest trying to get the retailer to replace it at no cost to you. If under warranty, the manufacturer should make it right? if both of those avenues are not available, then I would suggest get a new unit.
6/11/2015 7:17:27 PM • Magic Chef... • Answered on Jun 11, 2015
I need a manual for a Magic Chef 24 bottle wine cooler...digital.
help us help you What is the model number? Why do you need the manual? To troubleshoot? To operate or change settings? George
9/27/2014 4:04:25 PM • Magic Chef... • Answered on Sep 27, 2014
0answers
Capacity
Be the first to answer 5/23/2014 3:41:46 AM • Magic Chef... • Posted on May 23, 2014Be the first to answer
2answers
We have a Magic Chef MCWC52B
The light may be old, and need repairing, I would try contacting somebody local rather than buying a new one.
5/17/2014 7:41:19 PM • Magic Chef... • Answered on May 17, 2014
Magic Chef MCWC30MCG Compact Wine Cooler Logo
202 questions posted
Top Magic Chef Furniture Experts
ZJ Limited
ZJ Limited
john h
Are you a Magic Chef Furniture Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Furniture
Most Popular Question
magicchef wine cooler stopped working
  • Furniture
