Innova 3100 OBD II Code Reader Logo
Connie Ledesma Posted on Oct 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i reset my innova 3100 scanner - Innova 3100 OBD II Code Reader
how do i reset my innova 3100 scanner
  • Kenneth T Lucas
    Kenneth T Lucas Mar 16, 2019
    Hi Luc I have an Innova 3100 abs. I used it on a Dodge Truck now the codes are froze in the reader how do I get it out. I can't get it to work on any other vehicles now.
Simon Templar
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on May 27, 2021
Simon Templar
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
14674
Points
7
MY Innova 3100 OBD II don't have a reset hole behind? :(
Luc Francoeur
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 102 Answers
  • Posted on Oct 16, 2014
Luc Francoeur
Expert
Level 2:
Cheetah:
Night Owl:
Answers
102
Questions
0
Helped
44226
Points
298
If its a firts generation look behind of the battery tab. there is a reset hole that you must push with a pperclip
  • Axis
    Axis Nov 18, 2023
    Il n'ya pas de bouton derri?re le mien innova 3160g . Comment r?initialiser s'il vous pla?t
My Innova canobd2 wont allow me to scan any other vehicle Please help
NO car told at all, maker yes,model no, and year no.
In USA the first OBD2 car is 1996. so there is that fact.
this is easy stuff scan tools
rule #1 besides ,Innova batteries good.
1: pin 16 on the OBD2 DLC jack must be 12vdc, if not the fuse is blown in the car. bingo , CAUSE.
rule #2, old scan tools from 1996 to even 2007 can not do new cars CAN_bus communications at all and in fact the 2 pins on the tool are (if)missing, pin.6 and 14 pair. is can_bus.network is missing.
YOU SAID OTHER VEHICLES FAILS BUT GAvE NO EXAMPLES.
NOR TOLD THE INNOVA MODEL.# I have many here..
IF the tool is old, most these car will fail
http://www.auterraweb.com/aboutcan.html
the best tool is in fact marked CAN_BUS certified..
OBD2 is a USA invented standard and works on all cars here 96up
but CAN_ bus was added later, each tool maker added it , as late as 2008, some were slow. 2004 is better year to do it but many did not.
All do now. modern tools not old NOS (new old stock tools)
ABS and SRS is a totally other story.
topic engines ONLy.
the original Innova 3100, (old) fails on most new cars, lacks can-bus
they kept the name 3100 and added a letter to the end that fixes this problem. but is newer tool, (no free upgrade)
t reset the tool, unplug it from car.
remove all tool batteries for 15min and put back./
the tool does not lock up to any car it is just a passive receive only scanner, it can not transmit and exercises cars devices..
id does allow reading all engine sensors live, PIDs or some transmissions..
Innova pretends their oldest tool 3100, (ver0) dose not exist, they have zero info or support on their old tools.. 3100G,F,J,"SR" and up yes.
yes the told has CARS PCM DTC reset button and does work , but not if CAN_bus not supported in the tool.
How do you use a innova 3020b code scanner?
The scanner check procedure for Innova or Innova venturer is as follows:
(1) Turn the ignition switch to OFF (disconnected);
(2) Plug the scanner power cord into the cigarette lighter holder;
(3) Connect the scanner to the diagnostic communication circuit or the diagnostic socket of the check connector;
(4) Turn on the ignition switch; start the scanner to check the fault code;
(5) Turn off the ignition switch for troubleshooting and analysis, then turn on the ignition switch, and use the scanner to erase the stored fault code;
(6) Take off the scanner.
2answers
Why does my innova 3100 obd2 scan gives err message on obd2 certified car ?
Because it is likely not up to date on CAN BUS technology, an uprade is suggested.
2answers
Top Innova Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
