20 Most Recent Innova 3100 OBD II Code Reader Questions & Answers
2answers
How do i reset my innova 3100 scanner
if its a firts generation look behind of the battery tab. there is a reset hole that you must push with a pperclip
11/18/2023 8:00:11 PM • Innova 3100 OBD... • Answered on Nov 18, 2023
It just stopped working and will not come back on
contact the company
5/20/2015 7:18:14 PM • Innova 3100 OBD... • Answered on May 20, 2015
0answers
0answers
2answers
Need user manual for w5746
Same exact features, buttons and functions as this manual by Irwin.
http://www.irwin.com/uploads/documents/36_laser_tape_25.pdf
4/17/2024 8:59:53 PM • Measuring Tools... • Answered on Apr 17, 2024
Rf tech 433mhz manual model 217S31
I want to use an old sensor forgiven during 30 years. I have no more manual, off course. Thanks for your answer
3/26/2024 11:42:40 PM • Measuring Tools... • Answered on Mar 26, 2024
What are the readings on a meoisture meter measured in?
Most moisture meters measure the moisture content of wood or concrete is measured in percentages. So if the reading says 15 that means that there is a content of 15% moisture in the concrete.
3/16/2024 7:34:55 AM • Measuring Tools... • Answered on Mar 16, 2024
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
2/19/2024 4:57:31 AM • Measuring Tools... • Answered on Feb 19, 2024
Will one of the newer sensors work in place of my 1457 sensor?
It's possible that one of the newer sensors could work in place of your 1457 sensor, but it depends on the specifications of the newer sensors and the compatibility with your base unit. The I MAX1457 sensor, which is a highly integrated analog-sensor signal processor optimized for piezoresistive sensor calibration and compensation. However, I have no information about its compatibility. If you're looking for a replacement sensor, I suggest contacting the manufacturer of your base unit to inquire about compatible sensors. Alternatively, you can check the user manual of your base unit to see if it lists compatible sensors. Garage door opener sensors are not universal. Safety sensors can only communicate with garage door openers from the same brand.
1/21/2024 4:20:12 AM • Measuring Tools... • Answered on Jan 21, 2024
DSE Z111 Weather Station: Is the wireless sensor available for sale?
Unlikely unless you know the secret maker name and can find them in China. At the moment, no one has heard of it apart from here on Fixya. All questions need FULL 'make model (what it is)' please. https://www.google.com/search?q=dse+z111 ..
1/20/2024 1:59:56 AM • Measuring Tools... • Answered on Jan 20, 2024
How can I adjust the time on my weather station model #sgr72914?
  1. Access the Time Setting Mode:
    • Locate the 'Set' or 'Settings' button on your weather station. This button is typically found on the front or the back of the unit.
    • Press and hold the 'Set' or 'Settings' button for about 3 to 5 seconds. This action should access the time setting mode, where you can adjust the time.
  2. Adjust Hour and Minutes:
    • Once in the time setting mode, use the 'Up' or '+' button to increase the hours and the 'Down' or '-' button to decrease the hours.
    • After setting the correct hour, press the 'Set' or 'Settings' button again to move to the minutes setting.
    • Use the 'Up' or '+' and 'Down' or '-' buttons to adjust the minutes accordingly.
  3. Confirm the Time:
    • Once you have set the correct time, press the 'Set' or 'Settings' button again to confirm and exit the time setting mode.
  4. Check the Time Display:
    • After setting the time, check the display to ensure that the time is displayed correctly.
1/7/2024 9:28:03 AM • Measuring Tools... • Answered on Jan 07, 2024
Starrett Tape Measure. Can I Replace a 1.5 volt Battery with a 3.0 volt Battery in it?
Question edited for clarity. Question moved from Motorcycles category. Of course not! You will burn out all the electronic components. You can't just double the voltage. Conversely you can't put a 1.5 volt battery in place of a 3 volt one. Get the proper battery. https://www.starrett.com/contact-us# ..
12/20/2023 4:55:24 AM • Measuring Tools... • Answered on Dec 20, 2023
Innova 3100 OBD II Code Reader Logo
Popular Tags
13 questions posted
Top Innova Measuring Tools & Sensors Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Innova Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • Innova Measuring Tools & Sensors
Most Popular Question
reset innova 3100 scanner
  • Measuring Tools & Sensors
