Grill master model sl1323
Try this site
https://www.manualslib.com/
SOURCE: Owners Manual Needed Grand Gourmet Pro Model SG600
Call 1-800-694-0013 and they will e-mail you the 25 page instruction booklet!
Jerry S
SOURCE: Kenmore grill 141.52270
I don't know about downloading...All Kenmore products are made by other manufacturers. I don't know who makes the grills but you may want to explore Sear's own site to see if a comparable unit is shown...or simply buy one from Sears for a few dollars. Go to their parts site.
SOURCE: Kenmore Master Flame Grill
Burner will not light:
Here is a couple things you can check:
1. Gas injector not insert in venturi tube.
2. Clogged gas injector
3. Obstruction in gas line.
4.Spider webs in venturi tubes.
5. Misalignment Of collector box and burner.
6.Dead Battery.
7.Check hose to make sure it is not kinked
8.Check Hose to make sure it wasn't chewed by squirrles
9. If it is LP gas, Could be out of gas.
Other Issues:
Could be the way the grill was turned on and off, that also can be an issues. In your manual it will tell you how to do it proper, this could make it not light or have a low flame. If there is not hing in your manual, I will be happy to assist you.
Fireplace-Girl
SOURCE: Instruction Manual for Thane Q-grill.
go to this site http://www.thane.com/manuals/manuals.php then scroll down to the Thane Q-BBQ Grill manual, select it and it will open in PDF formate so you will have a free instant manual.. if this helps please rate me and let me know..thanks and good luck!
SOURCE: Need owners manual, Perfect Flame Grill, Model #E3520-LPG
are you using a swap n go gas tank??? Some have been known to vacuum lock at the valve. This is usually caused when the tank is turned off before the burners are turned off. To fix, turn off tank; unscrew hose attachment at valve; turn tank valve on, now screw on your hose. See if this gets you a bigger flame.
