Equestrian Logo
A
Anonymous Posted on Aug 14, 2014
How do i build a saddle?
Noob sorry
Matthew Walter
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Nov 02, 2018
Matthew Walter
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
5638
Points
30
Google what kind of saddle you want to make and get the blue print or patterns just like when you want to sew something you need patterns to cut leather and know how to put it all together
Where's the " do not remove disc "is supposed to go. Sorry guys I'm noob.
obviously or you would know to include make, model year where you were working on etc before asking the question
ask the question again with the photo and all the details
Noob meaning
NOOB=a person who is inexperienced in a particular sphere or activity, especially computing or the use of the Internet.
Low volume of water coming out of dispenser
okay well could be alot of things
1st could be calcium build up if you have copper lines
2nd could be your pump back side at the bottom
3rd could be your saddle. okay what's a saddle http://compare.ebay.com/like/220495328326?ltyp=AllFixedPriceItemTypes&var=sbar&rvr_id=222624104119&crlp=1_263602_304662&UA=%3F*I8&GUID=5fd4c6ce12b0a02652c6e516ff2a3e7e&itemid=220495328326&ff4=263602_304662
this is the saddle try this first if you have one of these. that lever on top opens and closes to turn the water on and off it's really a small needle that punctures the copper pipe well some times calcium builds up in there turn the water off and on a couple time useing this and see if that improves it if you notice more water coming out more and more well there you go. if iwhere guessing and say that is it. good luck
You fricken noobs need to get your **** together or im gonna kill myself and frame you
I am sorry for your inability to find a helpful response to your issue.
These things indeed can be frustrating, however if you are serious
as to killing yourself or anyone else call 911.
1helpful
There is no water reaching my AprilAire humidifier, indeed no water is flowing through the saddle valve attached to the hot water pipe of the hot water heater. Considering what would be involved in...
Yes a new valve seems in order. and yes having the valve on the cold side would create less build up in the filter pad so long as your water dose not come in at 37 degrees. but, I think you have it right.
2helpful
Saddle valve on water line to refridgerator won't shut water off
If you can not shut the valve off then most likely it has calcium build up in it. I would recommend shutting off the water supply at the angle stop. Then removing the saddle valve and see what is going on. If it is built up with calcium you may be able to clean it depending on how shot it is. If you are unable to clean it then a new one is not that expensive and they are easy enough to replace
Not sure about buying this saddle
The saddle itself is quite well made and should last a good while with proper care and maintenance. However, three things concern me and one is that it is a saddle you are used to using. If you are used to the support of a western saddle and move to a close contact, it may be very uncomfortale until you get used to it. The second is that the horse you use it on is used to being under a close contact saddle. The third and most important is that you indicate that you ride ' all different horses and ponies '. You do not clarify if you are wishing to use one saddle on all. I do hope not as saddles are not one size fits all. The saddle must be fitted to your 'seat' and the tree width and rise must properly fit the size and shape of the horses back. If you are unfamiliar with this, I suggest you learn how to fit a saddle before buying anything.
Ice mover stopped working Kenmore model 363.9557710 purchased Jul 96
Yes....I can definitely see all your posts. Sorry I don't have a solution for you. :(
Top Equestrian Experts
Imagdrider
Level 1 Expert
john h
ADMIN Andrew
ADMIN Andrew
Are you an Equestrian Expert? Answer questions, earn points and help others
