2006 Kia Optima Remote 2007 body style - Used Logo
A
Anonymous Posted on Apr 05, 2014
P0106 Error code p0106
tom_w64138
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 17 Answers
  • Posted on Oct 14, 2019
tom_w64138
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
17
Questions
Helped
3742
Points
34
I have typed car codes into google . and google will most times print out what the code means good luck.
Fault codes p0106, p0121 daewoo lanos 2002 1.6i sport
Definition of Diagnostic Trouble Code P0106 Category: Powertrain Definition: Manifold Absolute Pressure/Barometric Pressure Circuit Range/PerformanceNote: This definition of P0106 is applied to all manufacturers
Definition of Diagnostic Trouble Code P0121 Category: Powertrain Definition: Throttle/Pedal Position Sensor/Switch "A" Circuit Range/PerformanceNote: This definition of P0121 is applied to all manufacturers
P0106 error code
P0106 Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
kess v2 ecu tunning
1helpful
Code p0106 2005 hummer
The P0106 DTC trouble code refers to the Manifold Absolute Pressure sensor or "MAP sensor"
2000 ford ranger P0106 engine code
p0106 is a map sensor code and p0170 is a lean code i would look for a vacuum leak that would cause both codes
2answers
2006 cobalt ss 2.4 automatic trans. check engine light code p0010 p0106
Code P0010 Intake camshaft position actuator solenoid control circuit ( CMP )
most common cause is a bad solenoid, but it could be many componets that could cause the code, if you want to try to repair it on your own the only thing you can do is replace the solenoid, all other componets require some speclized test equipment.
code P0106 manafold absolute pressure sensor ( MAP )
check for a good vacuum source to the MAP sensor if there is a good vaccum source then replace the sensor.
good luck
2helpful
P0106 map sensor code on tdi
02 jetta map sensor code p0106 and faulty boost sensor code p0238
3helpful
DTC P0106 mazda protege. code came on, cleared
Check connections etc at MAP sensor. If all good, replace it. Erase codes & retry. How's vehicle running, idling, any black smoke out tailpipe?
3helpful
P0106 error code
Very simple. Disconnect the plug from it, unscrew, replace with new sensor and o-ring.....2 screws hold it on.
Top Car and Truck Remotes.com Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Car and Truck Remotes.com Vehicle Part and Accessory Expert? Answer questions, earn points and help others
