Refrigerators Logo
A
Anonymous Posted on Mar 25, 2014
Compresor fan everest refrigeration #etbf1
Everest esr1 refrigerator
Yes, it does exist,. It is a commercial reach-in refrigerator.
ESR1 ' Everest Refrigeration
everestref.com > product > esr1
Description. Everest's Upright Top Mounted Reach-In Series offers an outstanding combination of refrigerator, freezer, and dual temperature options as well as full ...
Everest Refrigeration ESR1 29-1/4" One Section Solid Door ...
www.restaurantsupply.com > everest-refrigeration-esr1-...
The ESR1 is a 29-1/4" wide, one-section stainless steel insulated upright reach-in refrigerator from Everest Refrigeration with 1 full-size self-closing and field ... Door Style: Swing
Number of Shelves: 3US$2,176.00 · ‎In stock
Everest ESR1 29-1/4" Solid Door Upright Reach ... - Amazon.com
www.amazon.com > Everest-ESR1-Refrigerator-29-25...
Buy Everest ESR1 29-1/4" Solid Door Upright Reach-in Refrigerator, 23-Cubic Feet, NSF: Refrigerators - Amazon.com ? FREE DELIVERY possible on eligible ...
Everest Refrigeration ESR1 29" Solid Door Reach-In ...
www.therdstore.com > page > IFSES > PROD > ESR1
Shop commercial refrigeration equipment at Restaurant Depot. Commercial refrigerators, commercial freezers, merchandiser or beverage cooler for your ... US$2,175.72 · ‎In stock
2answers
Refrigerator repair
how burned compressor looks like inside. opened it up.
Comoressor fan very slow
try to provide more details, any strange noises? what type of compresor is it?
Fridge and freezer stopped working lioghts still work
check if the compresor still working first then the fan next to the compresor ...then the fan in the freezer , then see if there is frosting inside the freezer evaporator, but the main part is the compressor starter unit next to it... that might be the problem :)
1helpful
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
1helpful
Motor keeps shutting off
It's a problem very common on this brand of refrigarators that the compresor relay goes bad and needs to be replaced(located on the side of the compresor under the black plastic cover).
Condensor fan runs but the compressor wont start
Either you have abad comoresor or abad compresor relay ,i will try to replace the relay first(if you don't have away to check the compresor) wich is cheaper (about $20 for the part)If doesn't work the compresor is burned or stuck.
Top Everest Refrigeration Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
