20 Most Recent Everest Refrigeration ETR2 Questions & Answers
manual
2answers
Refrigerator repair
how burned compressor looks like inside. opened it up.
6/12/2016 3:07:50 AM • Everest... • Answered on Jun 12, 2016
0answers
0answers
Compresor fan
Be the first to answer 3/26/2014 3:27:51 AM • Everest... • Posted on Mar 26, 2014Be the first to answer
0answers
Cone error 4
Be the first to answer 1/22/2014 7:48:41 AM • Everest... • Posted on Jan 22, 2014Be the first to answer
0answers
An ESR2 is not cooling
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/12/2011 2:30:34 AM • Everest... • Answered on Aug 12, 2011
Freezer temper 25 (selected -4) 2
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
7/12/2011 1:55:03 AM • Everest... • Answered on Jul 12, 2011
Suction pipe is freezing up
There is either too much refrigerant in system or its running and not cutting off on cold control/pressure switch,,....or the evaporator fan is not running...
1/16/2011 7:40:46 PM • Everest... • Answered on Jan 16, 2011
How to remove drip tray at back of aeg fridge
On an AEG SANTO 3533, the tray sits on top of the compressor. There is a short metal "tunnel" on top of the compressor. The tray has a plastic clip in the middle which goes through the tunnel and latches up on the other side. To remove, reach to the back of the metal in the middle of the tray, press the plastic clip firmly down, and pull/wiggle the tray backwards horizontally to remove. Needed a torch to see clearly on mine. One of these things that's easy once you've done it once.
4/16/2024 12:09:58 PM • Refrigerators • Answered 2 days ago
When Should You Consider Copper for Water Storage?
Copper has anantibacterial effect. Studies recommend storing water in copper containers for several hours before consumption to maximize this benefit. Some research suggests 48 hours. perhaps explore dedicatedcopper water bottlesfrom reputable sources for optimal water storage. This refers to water, not juices.
4/15/2024 9:35:54 AM • Refrigerators • Answered 3 days ago
I have a 1984 Norcold 8310 series RV refrigerator that isn't working. How can I troubleshoot it?
Question edited for clarity. Help and videos in the link. However it is 40 years old and has probably seen better days. There isn't much you can do if it needs refrigerant gas as you need a certified engineer. https://www.google.com/search?q=1984+Norcold+8310+series+RV+refrigerator+that+isn%27t+working ..
4/13/2024 5:04:34 AM • Refrigerators • Answered on Apr 13, 2024
3answers
Is it normal that the compressor is too hot too touch?
yes it is
4/9/2024 3:41:40 AM • Refrigerators • Answered on Apr 09, 2024
Question mark flashing next to temperature numbers
All questions need 'make model (what it is) first 3 words please. https://www.google.com/search?q=Refrigerator+Question+mark+flashing+next+to+temperature+numbers ..
4/6/2024 11:28:44 PM • Refrigerators • Answered on Apr 06, 2024
2answers
Freezer is over freezing resulting in the the fridge not cooling. model of fridge RS22DCMS water dispensing upright fridge freezer
Sometimes the timer jmalfunctions and the refrigerator will not go in to a defrost mode. Try unplugging it and defrost the refrig and plug it in again.
4/5/2024 9:37:23 AM • Refrigerators • Answered on Apr 05, 2024
Refrigerators Logo
0 questions posted
Top Everest Refrigeration Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you an Everest Refrigeration Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Everest Refrigeration Refrigerators
Most Popular Question
noi power compressor
  • Refrigerators
