SOURCE: door locked/ cycle won't complete
If you need to get the washer door open, there is a manual release lever that you can use. The following links explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
Now, with your clothes rescued, the next link explains the "F11" error:
http://www.fixya.com/support/r666194-f11_error_whirpool_duet_kenmore_elite
I know it seems like a lot with the second link. In most cases I have found, the CCU is the cause of the F11 error code, but read through the information carefully and doublecheck everything. It can be replaced if you wish to perform the repair yourself. I hope this helps you.
SOURCE: stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
SOURCE: Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
SOURCE: The washer fills just fine, but when it starts to
I do home inspections, and this is a no-no! GFI devices are not real happy with inductive loads, such as motors and refrigerators. Generally during home inspections, we find that GFI's older than 10 yrs. have a 75% failure rate using a sophisticated tester. The 5 yr. old devices are at 50%. I'd replace that outlet with a single outlet, dedicated to the washer. If it's near a sink, then you're required to stick with the GFI. I'd just repalce it with a new one. Good Luck!!
SOURCE: I have a Whirlpool Duet Sport (Model #
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$#$#
