Beverage-Air MT27 Beverage Cooler Commercial Logo
A
Anonymous Posted on Jan 28, 2014
HOW TO GET SPECIFICATION SHEET FOR MT27 BEVERAGE AIR
3 Related Answers
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Nov 17, 2009
SOURCE: Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Commercial Appliance Service, Inc.
  • 81 Answers
  • Posted on Jun 20, 2011
SOURCE: water is leaking from my
The condensate is supposed to drain from the evaporator down to a pan underneath by the compressor. Is is possible that the tube is not aligned with the pan any more. It is simple to check, remove the compressor compartment cover and inspect the pan and the tube. If the tube is out of place, just reposition it. This is likely the problem you are having. Also make sure the pan is correctly positioned.
Anonymous
  • 4 Answers
  • Posted on Nov 18, 2011
SOURCE: What does the overload relay look like a
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
1helpful
2answers
Why is my Beverage-Air refridgerator running all of the time?
Door seals torn, poor air circulation over condenser coils or evaporator coil, defective thermostat, not defrosting or low on Freon.
APPLIANCE 911
Can i use a beverage air mt27 as a freezer
Nope, You Can not. Compressors for freezers are different and if it set up as an fridge, you will not have enough defrost (on freezers there are heaters)
What will make a beverage air mt27 not cool
Multiple reasons. Is it turned on & set. Is the fan inside & out turning fast. Is there frost on a line at the compressor Is the compressor outside cabinet s/b hot & vibrating continually. Is the condenser (attached to compressor with radiator) warm/hot & not plugged with lint etc between the fins. ?????
How to add refrigerant to mt27
You should check the condenser to see that it is clean. Is the compressor running? If you have a leak, putting in gas wont help. You need to look for oil on the components around the compressor, inside the cooling coil housing. Hope this helps good luck.
Wiring
Yes they do with majority of models...
1helpful
2answers
What does the overload relay look like a Beverage-Air MT27 Beverage Cooler Commercial
Top Beverage-Air Refrigerators Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
