20 Most Recent Beverage-Air MT27 Beverage Cooler Commercial Questions & Answers
2answers
I have a Beverage Air
Thats How To Replace Compressor on Beverage Air.
9/28/2020 6:13:01 AM • Beverage-Air... • Answered on Sep 28, 2020
My commercial refridgerator stays too cold
Defective cold control thermostat
11/2/2017 1:33:55 PM • Beverage-Air... • Answered on Nov 02, 2017
I have a 7 yrs old beverage air mt27. The issue
That temperature control assembly will most likely be the problem.
10/10/2017 11:49:22 PM • Beverage-Air... • Answered on Oct 10, 2017
MT27 has a noisy fan operation. Doesn't always
There are a couple of possibilities that could be causing this. I believe it is the fan blade. One could be that bracket that holds the fan motor in places could have loose screws, which would cause vibration. Another is that the mounting for the fan motor to the bracket could be loose. Another could be that the fan blade itself is slightly bent. Check the motor brackets screws, fan mounting screws and the blades. If all those are good, making sure the unit is unplugged you can turn the fan blade by hand slowly to see if it is dragging anywhere on the shroud around the coil or the coil itself. You could slightly bend the "clacking" blade to clear is that is the issue. Tom
10/8/2017 5:36:42 PM • Beverage-Air... • Answered on Oct 08, 2017
2answers
Why is my Beverage-Air refridgerator running all of the time?
Door seals torn, poor air circulation over condenser coils or evaporator coil, defective thermostat, not defrosting or low on Freon. APPLIANCE 911
6/25/2017 12:20:57 AM • Beverage-Air... • Answered on Jun 25, 2017
Can i use a beverage air mt27 as a freezer
Nope, You Can not. Compressors for freezers are different and if it set up as an fridge, you will not have enough defrost (on freezers there are heaters)
8/11/2016 4:47:15 AM • Beverage-Air... • Answered on Aug 11, 2016
How to add refrigerant to mt27
You should check the condenser to see that it is clean. Is the compressor running? If you have a leak, putting in gas wont help. You need to look for oil on the components around the compressor, inside the cooling coil housing. Hope this helps good luck.
8/11/2016 4:34:53 AM • Beverage-Air... • Answered on Aug 11, 2016
I have a Beverage-Air MT27 and the door sags down on the side opposite the hinges and also leaves an air gap at the top on that side. I have tried adjusting to no luck. Any suggestions?
can you unbolt lower hinge from Door and put thin spacer between hinge and door. that should lift opposite side.
3/22/2016 3:24:18 PM • Beverage-Air... • Answered on Mar 22, 2016
Sparks coming from compressor, smells like burnt rubber
Sounds like the wiring has shorted that connects to the compressor. Shut the power off and remove the cover to the compressor terminals. You should see what you are looking for.
10/18/2014 6:21:07 AM • Beverage-Air... • Answered on Oct 18, 2014
Fan runs constant
The fan is supposed to run constantly and they do get noisy. Take it out and go to grainger or a refrigeration supply house and they will match it up with a replacement. Its a very common part. Good luck and hope this helps.
10/18/2014 6:02:30 AM • Beverage-Air... • Answered on Oct 18, 2014
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
10/18/2014 5:45:07 AM • Beverage-Air... • Answered on Oct 18, 2014
Cooler keeps freezing product
You killed the messenger! The refrigerant charge is probably the problem. The thermostat senses the coil temperature and not the cabinet temperature. If somebody put gas in it, the gas has to be removed, a vacuum drawn on the system and then the refrigerant charge weighed in by the ounce. It takes a critical charge and needs to be weighed in by an accurate scale that weighs in ounces. Hope this helps and good luck.
10/18/2014 5:39:41 AM • Beverage-Air... • Answered on Oct 18, 2014
What could cause the cooler to freeze other than a faulty thermostat?
Improper refrigerant charge. Its critical and measures coil temp and not cabinet temp. If you did add gas that is the answer. Take out all the gas, put vacuum pump on it, then weigh in exactly in ounces the correct charge, its listed on the spec. tag. Hope this helps and good luck.
10/18/2014 5:34:04 AM • Beverage-Air... • Answered on Oct 18, 2014
What will make a beverage air mt27 not cool
Multiple reasons. Is it turned on & set. Is the fan inside & out turning fast. Is there frost on a line at the compressor Is the compressor outside cabinet s/b hot & vibrating continually. Is the condenser (attached to compressor with radiator) warm/hot & not plugged with lint etc between the fins. ?????
7/1/2014 3:46:22 PM • Beverage-Air... • Answered on Jul 01, 2014
0answers
Beverage-Air MT27 Beverage Cooler Commercial Logo
77 questions posted
Top Beverage-Air Refrigerators Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Jorgie  the...
Jorgie the...
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Refrigerators
Most Popular Question
beverage air refridgerator running all
  • Refrigerators
