Links on watch band do not have pins. How do I remove links?
SOURCE: Remove links from metal watch band
This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
I used a neoprene mouse mat as a work surface, which was ideal as it
allows the pin to move out, whilst supporting the links and stopping
any slippage. I also rigged a table lamp close by.
There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
SOURCE: we have a lp27003tt piccard
I dont know what kind of band that is, but the link following shows you how to do several of the basic pin-push style that most watches are.
http://www.webwatches.co.uk/how_to.htm
Place the watch face down on the cloth. This will help keep your watch from being scratched.
Examine the links closest to the buckle. These links will have small pin holes on each side of the link, as well as a small arrow engraved on the inner side of the band. These indicate the direction the pins must be removed.
Place the driving tool (a thumbtack will work) inside the pin hole in the band and push the pin out in the direction of the arrow. Remove the pin carefully from the other side.
Repeat Step 3 to remove any links needed to adjust the band properly.
Reattach the band to the buckle. Attach each end of the buckle back to the bracelet, driving the pin in the opposite direction from how it was removed (opposite the arrow).
