20 Most Recent Lucien Piccard 26024 Wrist Watch Questions & Answers
its sound simple enough but you will need to use a bit of force to budge the pin.
you will need
blue tack
punch
pin hammer
pliers.
Roll up the blue tack push onto flat surface , push the barcelet side on into the blue tack wthe arrows pointing downward.
insert the punch into the hole and tap with hammer.
do this until you have removed enough links then push a pin back into the bracelet and tap home withthe hammer.
Lucien Piccard... | Answered on Aug 29, 2017
i only found some for women sorry !!! http://www.newegg.com/Product/Product.aspx?Item=9SIA01C0001NU2&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-Watches-_-Lucien+Piccard-_-9SIA01C0001NU2
Lucien Piccard... | Answered on Dec 14, 2016
This was on a Seiko Dive watch SKX007. This has the metal links joined with pins, which, you will find, are split/spring down their length.
I used a neoprene mouse mat as a work surface, which was ideal as it allows the pin to move out, whilst supporting the links and stopping any slippage. I also rigged a table lamp close by.
There is an arrow which shows in which direction the pin needs to be pushed to remove it. Look carefully and you see that one end of the pin is slotted a little, the other is plain. Push the plain end in the direction of the arrow firmly... it's a leap of faith.
As a tool, I used a cocktail stick to start with. It required firm pressure and then it suddenly gives. I was able to draw the pin out by hand, but used pin nose pliars in one instance, as some pins offer more resistance than others. In most cases the cocktail stick worked (I got through a few). I then graduated to a thumb tack which was more reliable, but metal to metal, so a bit more worrying.
Sliding the pin back was simple, though take care to get the smaller links the right way up when it is re-threaded. I pushed it home the last few millimeters with the flat side of the pliers, giving a final push with the cocktail stick. Good luck. Simplysimon.
Lucien Piccard... | Answered on Dec 07, 2015
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Lucien Piccard... | Answered on Dec 04, 2014
My Citizen Skyhawk analog UTC hour hand is always 9 hour back of the UTC digital hour. I've tried to reset and hour/min hand alignment process without success.
Lucien Piccard... | Answered on Jul 23, 2013
Browse through my Tips and Tricks. There you will find how to add or remove links.
Lucien Piccard... | Answered on Jan 29, 2013
Lucien Piccard 26024 Wrist Watch Logo
54 questions posted
Top Lucien Piccard Watches Experts
Janelle Schoonover
Janelle Schoonover
michaelrt616
Are you a Lucien Piccard Watch Expert? Answer questions, earn points and help others
View Most Popular
  • Lucien Piccard Watches
Most Popular Question
need remove metal
  • Watches
