First let us repair the terminology.
- You can evaluate any expression (find the value of any expression for a particular value of its variable).Store a value in the variable, say X. Key in the expression and press [EXE].
- You can consider your expression(should not contain a relational operator such as =, greater than, less than, greater than or equal to, less than or equal to) to be a function Y1(x) = expression and graph it, or generate a table for it. You will have several values of the function calculated at various points.
- You can set your expression equal to 0 and find the particular value(s) of the variable (the unknown) that make the equality TRUE. That is called solving an equation.
I am not sure that it has a solver (solving an equation or an inequation) but you can always draw your expression as a function and explore the graph (SKTCH) to locate the roots (or zeros) of the functions (the values of the variable where the function equals zero.) That is called solving graphically.
Hope it helps.
Thank you for using FixYa and for rating this solution.
