My laser Printer shows a message and do not prints any document. When i try to print any document. My printer shows a message "Toner Exhausted, Replace Toner". Plz tell me how can i solve my this printer's solution.
We have Zero cost solution for samsung -scx-4300, scx-4824/4828
ml-2240,ML 2245, ml 1640. clp 310/ 315, It is working permenently.
Refill cartridge is working for ever. which is running successfully.
also provide other new model reset solutions.
www.nakshatraworld.com
mob: 9713862555, 9893282285
[email protected]
Toner cartridges are sensitive and excessive temperatures, light and humidity can greatly reduce the number of prints. Keep your extra cartridges in an area where temperature does not exceed 104 degrees and away from direct sunlight and doesn’t have extreme changes in temperature or humidity. Further, the life of a toner cartridge can be extended by redistributing the toner in its cartridge, if you notice print quality decreasing. This can be done by removing the cartridge from the printer and gently rocking it side to side. However, this is only a temporary fix until it’s time to replace the cartridge altogether. get more information and help for toner exhausted replace toner . Hope this helps you.
4300
Put on your shoes, and walk or drive to the nearest office supply store, and get a new toner. Go home and put it on...ta-daaaaa!
SOLVED
