20 Most Recent Samsung SCX4623F Laser All-in-One Printer Questions & Answers
2answers
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup cong ty bao ve support good luck
11/25/2022 12:21:49 PM • Samsung SCX4623F... • Answered on Nov 25, 2022
Printer feeding multiple pages
After so much paper goes thru the rollers they pick up dust and dont stick. Some models you can unplug and then use a q tip soaked in alcohol to clean the roller. Others require you to take them apart to clean. If you have to take it in to get fixed then check out the new ones from a computer store. Sometimes its cheaper to get a new printer than go get yours repaired or cleaned. If you do decide to have it done look really close when they get done and ensure the rollers were cleaned with alcohol. Otherwise they mihgt still have a oil coating on then and that causes them to slip also, especially on photo paper. They will argue in some places that the alcohol will dry out the rubber and it will age and crack. Altho this is true I have yet to see a dry, aged or cracked pickup roller, even 15 years in the business. I think thats because it takes longer to age and crack a rubber roller than it does to just wear out the machine. Jonathon
12/9/2021 4:11:28 PM • Samsung SCX4623F... • Answered on Dec 09, 2021
Scx-4623f error not compatible toner
  1. Remove your new cartridge and replace it with the old one. Leave your printer and go and do something else for 10 minutes.
  2. Replace the old cartridge with the new one again. These two steps alone often resolve the issue, so see if your printer now recognises your new cartridges. However, if you're still having trouble...
  3. Remove the new cartridge. Make sure you place it in a clean and safe place where the cartridge or the surface won't be damaged.
  4. Turn the printer off using its power button
  5. Unplug your printer at the wall. It's important to do both steps 4 and 5 separately, as some printers can remain in sleep mode if you've only switched off the power button on the printer control panel. Leave your printer like this for about 10 minutes or so.
  6. Plug your printer back in at the wall (but don't press the power button just yet)
  7. Insert your new cartridge
  8. Press the power button on your printer
12/3/2021 3:33:30 PM • Samsung SCX4623F... • Answered on Dec 03, 2021
I HAVE SAMSUNG SCX4623F PRINTER I REMOVED &
try this:Test if microswitch who tell to printer that front door i closed is working propertly.If you can't test just make By-pass microswitch in your resposibility (because the printer will wor even you open a front door)I have the same error and I sloved in this way.
11/15/2021 6:41:51 PM • Samsung SCX4623F... • Answered on Nov 15, 2021
My samsung scx-4623f say door is open close it
door sensor lever disengage , pls check
11/15/2021 6:41:40 PM • Samsung SCX4623F... • Answered on Nov 15, 2021
2answers
When i print ,I get
You are most likely getting this message because of a paper size mis-match. For example, you are sending a print job as letter size but your printer is set to or has a4 size installed. When the printer sees that the print job is not a matched size to the paper in the tray, it will look to the manual feed tray for paper to print on, hopefully the correct size. Make sure your paper setting in printer properties on your computer match the paper in the printer and the print job "page setup" is also the same size/
11/6/2021 3:49:33 PM • Samsung SCX4623F... • Answered on Nov 06, 2021
I have a samsung scx-4623
Recommend contacting Samsung directly for assistance: Contact Us helpful-hhkqfx2w2zkuwwpsab3b1hzw-4-0.png
2/7/2018 2:38:55 AM • Samsung SCX4623F... • Answered on Feb 07, 2018
The communication between the computer and the printer have disconnected. Do a reset of the printer. Rest the parameters, like the IP Address, Pass Codes, etc. Check you DEVICES (Printers) to see if it is sending a Wi-Fi signal?
1/31/2018 11:51:56 PM • Samsung SCX4623F... • Answered on Jan 31, 2018
How do I replace the
What are the steps to remove the fuser? I have not been able to figure it out. Unless you disassemble the entire unit. Thanks
6/18/2017 1:02:53 PM • Samsung SCX4623F... • Answered on Jun 18, 2017
3answers
Samsung 4623FN when i refill
  1. Prepare a new cartridge of the color (K, C, M or Y) you wish to replace.
  2. Ensure that the printer is on with all covers closed, and that the Toner Low warning, Sleep, or Ready status is displayed.
  3. Press the right%20arrow%20black.jpg Right arrow button to display the menu.
  4. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Reset Menu is highlighted:
  5. Press the right%20arrow%20black.jpg Right arrow button once, this will enter the reset menu as shown below:
  6. Press the up%20arrow%20black.jpg Up or down%20arrow%20black.jpg Down arrow button to scroll through the options until Change Toner X (where X is K, C, M or Y) is highlighted for the toner you wish to change:
  7. Press the Right arrow button to start the removal procedure. The printers panel will read Please wait, then after a short delay the printer should display a red error light and the message Replace Toner X, where X is the relevant toner cartridge:
  8. Open cover D.
  9. Hold the toner cartridge knob and tilt it toward you.
  10. Remove the empty toner cartridge from the printer.
  11. Take the protective materials off of the new cartridge, and gently shake the new toner cartridge a few times.
  12. Take the new toner cartridge out of its package, and remove the plastic protective cover from the toner cartridge.
  13. Insert the new cartridge into the printer.
  14. Close the toner cartridge cover.
  15. Close cover D.
  16. If you need to change another toner cartridge, repeat the above procedure from Step 1.
TO view pics of the steps click here
9/10/2016 5:37:08 PM • Samsung SCX4623F... • Answered on Sep 10, 2016
I have samsung scx-4623F how do i connect printer to my acer computer
install driver form samsung website
10/2/2015 7:12:28 PM • Samsung SCX4623F... • Answered on Oct 02, 2015
What dose it mean?wait image2...
Dear You can try to upload the higher version firmware, some times it may revive the main PBA. The alternate is to replace the main PBA. But if some professionals are doing chip level repair and programming then you may take their help to restore the main pba. Thanks.
3/8/2015 4:05:02 PM • Samsung SCX4623F... • Answered on Mar 08, 2015
How do i copy 8 1/2 x 14 on samsung SCX-4623F
Dear You can use the ADF to scan the size documents. Thanks.
3/4/2015 5:00:00 PM • Samsung SCX4623F... • Answered on Mar 04, 2015
What is error code
Dear Its related to the fuser assy. Pl. check the fuser thermostat and heating lamp. for if its open replace it, check the thermistor resistance if it open replace it, Check SMPS. Thanks.
3/3/2015 8:29:45 PM • Samsung SCX4623F... • Answered on Mar 03, 2015
End of life replace new card
Dear The toner cart. has lapsed its life. As there is a chip inside cart. which keeps record of the page count and toner percent used. when predefined percent consumed it indicates. The replacement with new cart or replacement of the chip and toner powder resolve your problem. Thanks.
3/3/2015 7:44:57 PM • Samsung SCX4623F... • Answered on Mar 03, 2015
2answers
I use Ubuntu 10.04 and I want to install my
Hi there and welcome to fixya,
What's the model code for your printer?
There are three options;
XAX, XAA, XBG
For a direct link to the XAA type, follow the link below:
http://www.samsung.com/us/support/downloads/SCX-4623F/XAA
otherwise, you'll need to select the correct model code on the drop down.
On the Driver tab. Download the driver file under LINUX.
Hope this helps.
levbit
2/2/2015 2:02:34 AM • Samsung SCX4623F... • Answered on Feb 02, 2015
I need to scx4623f . seral :CRUM-11101637833 ver : 2.01.01.01 f please help me
Dear You have to follow online reseter on internet. usbprns3 printer reset Free Download . Thanks.
1/26/2015 3:06:24 PM • Samsung SCX4623F... • Answered on Jan 26, 2015
13answers
How to reset toner ,Samsung SCX-4623F
Just buy the reset chip!
11/11/2014 4:20:08 AM • Samsung SCX4623F... • Answered on Nov 11, 2014
How should i solve my printer it say manual paper empty
it sounds to me that your paper size is not correct so it is tring to pick from the bypass. put paper in the bypass until that job is over or delete that print job. make sure your paper cassette is set to the right paper size. most of the time this problem comes up when rinting pdf files or from the internet.
10/23/2014 3:23:34 PM • Samsung SCX4623F... • Answered on Oct 23, 2014
Samsung SCX4623F Laser All-in-One Printer Logo
170 questions posted
Top Samsung Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
scx 4623f error not compatible toner
  • Office Equipment & Supplies
