Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
With the original remote you would hit display, if no display on this remote you are out of luck. Sooner or later if display up all the time it will burn that image into the screen.
Not likely - - there is nothing on the remote that would cut-off the signal, unless you have selective inputs and you were not viewing the correct one. However, "cable" CH03 is correct if your satellite is attached to the screw-on "F" connector in the back of the Tv... When you press menu on the reciever does a menu appear on-screen??
Bill
