Stopped mid cycle, now shows up as err on the display, pressed the two buttons together to get the error code E66. Any help please?
E66 Suggests a heater relay fault on the pcb. It can also be triggered by a duff element (much cheaper). Check for low insulation & continuity of the heater.
Http://bastlman.wz.cz/2010/08/AEG-Lavamat-error-codes.html
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
