Any video input is black and white. I've tried 2 DVD players, and 2 yellow video input cords into each of the video component inputs (A single video input, not a component input, but it should work, yes?). The audio works fine, but the video is black and white, and has dots as well, almost like a comic book sort of feel.
It's not the DVD, the DVD player, or the yellow labeled video cords. Is there some way that I can reset everything to default using the remote? I've searched through the menu for ANYTHING, but to no avail. Maybe I missed something?
Hi I have exactly the same problem. Did you solve it? I just bought it, the tv works fine with colurs, but i plugged ti nintendo gamecube and the wii, (with different cables) and on both of them is black and white! please help! Hi I have exactly the same problem. Did you solve it? I just bought it, the tv works fine with colurs, but i plugged ti nintendo gamecube and the wii, (with different cables) and on both of them is black and white! please help!
AnonymousMar 04, 2009
I have the same daggon problem! How do I fix it??? I have the same daggon problem! How do I fix it???
You can't post conmments that contain an email address.
Red is for Left Audio Output, to TV Left Audio Input White is for Right Audio Output, to TV Right Audio Input Yellow is for Video Output to TV Video Input
You should see the same color coded RCA jacks on the rear of your TV unit. Just match the inputs to the correct device ie: Video 1, Video 2, etc
There are many methods to do this.
If your cable are ONLY RED,WHITE,YELLOW
1 Plug the red white and yellow cables to there corrosponding jacks on your DVD player
2 Plug the red white and yellow cables to jacks labled video IN, Audio IN. They will be colored on the back of your Tv
3 Plug in the power cable.
4 Turn it on and flip through the inputs on your tv until you see the picture
IF your cables are RED, GREEN, BLUE, RED, AND WHITE
1 Your are using what is called conponent video. This is a high definition video.
2 Three of your plugs are for video. They are Red(Cr) Green(Y) and Blue(Cb)
3 Plug the GREEN into the Y jack
4 Plug the RED into the Cr jack
5 Plug the BLUE into the Cb jack
6 Plug your power cable int o the wall if you havent alredy done so
7 Plug the other red cable into the audio right jack
8 Plug the white cable into the audio left jack
9 Turn it on and surf through the input until you find it
If you have a BLACK, RED and WHITE
Do the same as RED WHITE and YELLOW but
1 Put the black cable into the s-video slot
2 Surf through the inputs until you find the picture
If you have ONE BLACK CABLE
1 This is called HDMI(High-definition multimedia interface)
2 Plug one end into the tv and the other inte you dvd
Thank you for your time, Good luck and I hope this works
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors.
The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Your DVD player's output is Composite Video (the yellow connector) plus stereo audio (the red and white connectors, for right and left audio)
The inputs on your TV are for Component Video, which splits the video signal into three cables (Y for brightness, Pb and Pr for blue and red, respectively)
Check your TV to see if it has a composite input (single yellow connector, labeled "video" or "composite")
The ProScan will accept input on input 90/91/92 using the connectors on the backside. You can use S-video[the little round black connector] or the composite video [yellow connector] for the video in and use the red / white pair for audio in. 90 selects S-video and audio 1 in 91 selects composite and audio 1 in 92 selects composite in 2 and audio 2 in Connect these cords to the S-video or composite yellow output, and the Red-right White- left audio outputs on the DVD. If you don't want to do this, get a RF modulator ~$15, and connect the yellow/red/white from the DVD output to the inputs on the modulator, and then connect the RF [cable] output of the modulator to the antenna input on the ProScan, and tune channel 3 or 4. tom
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless) Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player. ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket RCA RED and White = TV screen A/V1 input red and white socket.
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV: Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD: Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
HDTV:
DVD:
