I want to do a factory reset. my owners manual does not say how to do that. Please advise, Thanks.
SOURCE: program manual for honeywell thermostat model T8700C1005(1)
go here: http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
SOURCE: Had electrician install RTH2310B Honeywell
check to make sure that it's wired correctly. R(red)power, G(green)common, Y(yellow)cooling, W(white)heating, O(orange), E(emergency)heat. Make sure that you have the correct thermostat because there is a heatpump thermostat and there is an air condition thermostat and they are wired differently.
Testimonial: "Thanks for the info but they appear to wired correctly so I will just check again. Thanks!"
SOURCE: How do I set the
To set the temporary override, press arrows up or down to desired temp. This will keep temperature
at temporary setting for 2 hours then return to programming. To permanent override press MODE button until schedule period number disappears (number inside little house on stat). Then adjust temp with arrows. Press the MODE button again to cancel override and return to programmable.
Here
is a tip that tells you how to get a manual for most any Honeywell
product online...
Manual
Honeywell How to Find Honeywell Manuals
heatman101
