Flashes and red error is burning.If i change battery will I have to reprogram as I have misplace book.
Check Sentry Safe Support for manual and programing.
If the batteries are low, the red light (in the
middle) will warn you immediately. To test the batteries, just input
your personal numbers to open the door. If the batteries are low, the
red light will be on. If nothing happens, it means that the batteries
are in order.
Yes u have to re program to do that ...
A. Locate the red button on the back of the door
near the light bulb. Turn on the light to locate it. Press it and
release it and you will hear two beeps. The yellow light will be on at
the same time.
B. Now press from 3 to 8 numbers that you wish to uses as a
combination, and confirm by pressing the letter “B” within 15 seconds.
Or you have to do it from the beginning over.
C. Write down your new combination immediately and with the home
wall safes door open check whether your new combination has been
programmed. Enter the new combination then press the letter A. Remember
A to open the home wall safe and B to change the combination.
If you do it quickly, re-programming may not be necessary. else, just visit Sentry website for the manuals
No not at all just changee the battery and carry on.
Thanks for using fixya.
No.only just changing the battery why to reprogram.it will work normally as u change the battery.
Yes,u will have to reprogram it
http://www.paragonweb.com/files/manuals/...
click this link
I do not have a book or infromation on reprograming.my safe is sentry 1620
