It wont run to what it shouls be on thermostat......tag stats on setting 4 my fridge should be around 36 degrees...it stays below 20....even at setting 1 the lowest setting its staying below freezng...from off to seeting one it does turn on compressor.....right now cant put beverages in it...freezing them up....what could the problem be
SOURCE: Beverage-Air DD50 Commercial Keg Fridge Not Cooling
The starting components on the compressor could be going bad. You need to turn off the thermostat and then after about five minutes turn it on while listening to the compressor to hear if it kicks in, if it doesn't then you might have faulty starting component, more likely the overload.
SOURCE: my BM23 beverage air kegerator runs constantly and
I would definately start there. That is what contols the cycling of the compressor.
SOURCE: What does the overload relay look like a
Normally thermal overloads have a button like appearance on the compressor. Designed to open circuit when temp has caused distortion to the bi-metal contacts. Upon cooling will close again. Disconnect power before checking continunity on the overload terminals.
SOURCE: Beverage-Air Kegerator Not Staying Cold
The internal temp will get down to 40 degrees but the fans won't shut off. We had to move it and when it defrosted, a lot of ice fell off the coils.
