You'll have to take it apart and check the rollers and pulley and also check around the front of the drum,there's a felt seal there that i've found the drum cuts through it or something could be stuck in the felt,pull out the lint filter and remove the two screws in front of it,then get a screw driver and stick it in between the top cover and the front panel around two inches from the corner and pop up the top cover,check the drum to see if it looks like something is rubbing against it.if so unplug the dryer,disconnect the wire connector on the right side,and remove the two 5/16 inch screws that hold the front panel on.watch video
http://www.youtube.com/user/RepairClinic?
v=zXg5iVKEel4&feature=pyv&ad=5621279621&kw=dryer%20felt%20sealalso while you have it apart vac it out.if nothing wrong with felt you can buy a kit with the belt,rollers and pulley to change them out,one of these should be your problem but metal on metal i would check the felt seal first.hope this helps and good luck.
