HP Printer Error 49 is normally caused by a communications failure between your PC and the printer. If you have an HP printer you may receive the HP Printer Error 49. This is normally effected by a communications breakdown between the printer and the PC, or related file errors.
Check this for Full solution- HP Printer Error 49
Hp 3050 Error code 49
Internal Embedded Software Error. Manual says to power off for 30 seconds. Power it on and let it initialize. If the error persists you will need a tech.
SOURCE: HP LaserJet M1522 with error 49
on hp.com you can update the firmware and that should take care of it. its a free download
SOURCE: error 79 hp laserjet m2727nf mfp; error 49 hp laserjet m2727nf mf
Bueno, el error 79 en mi caso se presentó con el servidor de impresion, tienes que limpiar los trabajos en cola y luego reiniciar la impresora.El error 49 indican que es con un problemas de fax o con scanear en Mac OS X, en todo caso hp support tiene los pasos a seguir.
SOURCE: Error 0X00000015. HP laserjet 3050 won't scan
If you need more help come back.Post /
thumbs / testimonial are
welcome!
Solution two: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
NOTE:
The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (
Figure 2: Example USB connection (your product might not look exactly the same as this example)
