20 Most Recent Peg Perego John Deere Gator HPX Questions & Answers
How do I open hood of john deere gator 620I 2008
the hood doesn't open on this toy but the front grill does flip down
8/18/2017 3:52:52 PM • Peg Perego John... • Answered on Aug 18, 2017
Valve adjustment 620i gator
this toy doesn't have a valve
8/18/2017 3:52:17 PM • Peg Perego John... • Answered on Aug 18, 2017
2004 lohn deere gator steering will get real hard
I f you are referring to the kids toy gator there is one nut on the front axle that can be loosened
8/18/2017 3:51:48 PM • Peg Perego John... • Answered on Aug 18, 2017
Electric won't move only the relay clicks. Rock
wrong category, this is for the gator toys
8/18/2017 3:50:15 PM • Peg Perego John... • Answered on Aug 18, 2017
How to remove axle gears
8/18/2017 3:47:22 PM • Peg Perego John... • Answered on Aug 18, 2017
How to remove the left side steering arm off a John Deere 750 MFWD Compact tractor?
there is no steering arm on this toy
8/18/2017 3:44:30 PM • Peg Perego John... • Answered on Aug 18, 2017
HOW DOES THE RACK COME APART
What rack? There is no rack on the toy gator
8/18/2017 3:43:58 PM • Peg Perego John... • Answered on Aug 18, 2017
Where can I find a replacement lucerne usa 5029 switch for john deere gator
wrong category this is for the toy gators
8/18/2017 3:43:16 PM • Peg Perego John... • Answered on Aug 18, 2017
Where is fuse panel location on john deere gator 4x6
there is no fuse panel on this toy
8/18/2017 3:02:26 PM • Peg Perego John... • Answered on Aug 18, 2017
John deere parts diagrams
8/18/2017 3:01:44 PM • Peg Perego John... • Answered on Aug 18, 2017
How to raise hpx john deere gator dump bed manually
just pull the red lever behind the seat
8/17/2017 2:34:51 PM • Peg Perego John... • Answered on Aug 17, 2017
Peg perego gator dump bed broken
could you please expand a little on when you say its broken? lots of these are assembled wrong with the rear black plastic pieces on backwards
8/15/2017 2:39:53 PM • Peg Perego John... • Answered on Aug 15, 2017
Need to rewire a peg perego 12 volt gator
sounds like you have a bad motor, try disconnecting one of the motors and then try it again
8/15/2017 2:39:02 PM • Peg Perego John... • Answered on Aug 15, 2017
How do you open hood of john deere gator hpx
the hood doesn't open, but the front grill does flip down
8/15/2017 2:38:20 PM • Peg Perego John... • Answered on Aug 15, 2017
Th charger light dont work when i plug the battery up
check the fuse on the battery
8/15/2017 2:37:17 PM • Peg Perego John... • Answered on Aug 15, 2017
Kids gator xuv won't go into low or reverse
do you mean the shifter physically won't move into those positions, or once its in those positions it doesn't engage the motors
8/15/2017 2:34:40 PM • Peg Perego John... • Answered on Aug 15, 2017
Works when foot pedal is not in place on floorboards but not when foot pedal is installed on floorboard
is there anything that is causing the wires to bind or come loose when its put back in
8/15/2017 2:32:53 PM • Peg Perego John... • Answered on Aug 15, 2017
Battery is charged but there is no power and won't start
check the battery with a multimeter and verify that it is showing at least 12 volts, also shake the battery a little and if it sounds like there is sand in there then its dried up
8/15/2017 2:31:59 PM • Peg Perego John... • Answered on Aug 15, 2017
I have a John Deere
probably a bad shifter switch you can order a new one here www.powerwheelsoutlet.com
4/1/2015 10:26:59 PM • Peg Perego John... • Answered on Apr 01, 2015
Kids john deere gator shifter won't go into reverse
I took the shift assembly apart. The switches weren't set in right. Once I put them in the shifter lined up and it works fine
4/1/2015 10:24:55 PM • Peg Perego John... • Answered on Apr 01, 2015
Peg Perego John Deere Gator HPX Logo
160 questions posted
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
View Most Popular
Peg Perego Toys
  • Peg Perego Toys
Most Popular Question
bought brand new gator
  • Toys
