20 Most Recent
JUMP START SYSTEM Questions & Answers
Where do I get parts for my Vector 350, 200 wt veco29acy ?
To find parts for your Vector 350, 200 wt veco29acy, you have a few options:
- Manufacturer: Start by contacting the manufacturer of the Vector 350 equipment. They may offer replacement parts or direct you to authorized dealers or distributors who can provide the parts you need. You can check the manufacturer's website for contact information or support resources.
- Authorized Dealers or Distributors: Search for authorized dealers or distributors of Vector 350 equipment in your area or online. These dealers may stock replacement parts for the specific model you have and can assist you in purchasing the parts you need.
- Online Marketplaces: Explore online marketplaces such as eBay, Amazon, or specialized industrial equipment marketplaces. Sellers on these platforms may offer replacement parts for Vector 350 equipment, including the specific model you have. Be sure to verify the compatibility of the parts with your equipment before making a purchase.
- Equipment Repair Shops: Local equipment repair shops or service centers that specialize in food equipment may have access to or be able to source the parts you need. Contact them and inquire about their ability to provide replacement parts for your Vector 350 equipment.
When searching for parts, make sure to provide as much detail about your equipment, including the model number (Veco29acy) and any specific part numbers or descriptions if available. This will help ensure that you get the correct parts for your equipment.
Where can I get a manual for Vector vec012 jump start system?
hello
u will find a lot of wiring diagrams, codes etc and circuit diagrams help books and stuff like this at online places.. like reliable-store
for free
the girl in the chat box can help u instantly... im a frequent buyer there since Im a mechanic so take help from there
I have a Power on
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals free
Jump stavec012c
I live in Brunswick Ga, can you tell me where to find a replacement ac charging plug and the cigarette lighter plug for my Vector Jump Start 450 amps,(VEC012c).Thank You Mr. Prior
Need power cord where to
I cannot see the manufacturers name. If you get me the manufacturers name and the model number then I'll be able to find out where you can get the power cord.
I changed the starter in my 2009 pontiac g3 and its acts as it the battery is dead with no charge. I starter sounds as if its trying to start jus not strong enough. What else could be the problem. The
I suggest you keep trying to start for 3 or 4 ten second bursts with ten seconds between each. Dragging current through a poor connection will tend to cause heating of the connection. Immediately feel each battery connection and each connection along the battery leads to the starter motor not forgetting where the earth leads connect to the bodywork.
Using a voltmeter to measure the volt drop along the leads would be an easier way to check the leads and connections.
Pay particular attention to terminals that are crimped to the cables rather than being soldered. Sometimes there is a dirty connection inside the crimp where it can't be seen or cleaned and the only cure is to cut it off and replace it with a more conventional type of soldered terminal.
It might be a good idea to start with to test the new starter to ensure it is good....
Power cord vector start it VEC012
Here's a link to the power charger I needed, its a Black & Decker Replacement A/C Charger. I ordered it at the following:
http://www.amazon.com/Black-Decker-5140045-42-Replacement-Charger/dp/B002V6VIZW/ref=sr_1_1?s=hi&ie=UTF8&qid=1445366598&sr=1-1&keywords=Black+%26+Decker+%235140045-42+Replacement+A%2FC+Charger
How do you recharge the system
What kind of battery are you asking for? Get yourself a good battery charger and follow the directions found in the box. It will explain everything you need to do.
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
I have a vector 300 amps that will not charge or hold a charge.This is the first time i needed a jump and did not work!It must be a MANUFACTURER DEFECT.What to do? Your Customer
This unit contains a sealed lead acid battery. As such it is necessary to maintain the battery much as you would an RV or tractor or other occasional use battery. If you left the charger plugged in all the time, that's what killed the battery. If you charged it less than once every two or three months, that's what killed the battery. If you stored it in a cold place it may have sulfated. If you stored it in a hot place it may have dried out, especially while charging. The good news is that a replacement battery is not expensive and you can install it yourself. Pull the case apart (look for hidden screws). You may find a good YouTube video to help. Unplug the battery and either shop on-line or go to a battery plus store. But remember, the old SLA battery models like this are rapidly being replaced with LiPoly units that have very good latency (storage) without loss of power. You can get a good one for around $100.
