20 Most Recent Electric Demolition Jackhammer Questions & Answers
H45sb start but dont hammering
Or a 320825 CONNECTING ROD or worn striker / or second hammer this is a very high priority very critical peace because of its a 2 millimeter 2 short difference sometimes to measure it will not good reach each other because of the chicel. must can get an idle mode if there is no push and by Hitachi you never believe it it gets worn you should see the difference with new parts pos 12 until 25 (parts 24 and 18 are the high priority parts together) its not a good idea to service a hammer where gaskets seals or o-rings are not fully air-tight. then the o-rings are burning again in a very short time because the tool becomes inside dry and overheat if its starts leaking https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+45SR&newwindow=true
9/12/2016 1:45:33 PM • Electric... • Answered on Sep 12, 2016
Kango 900 hammer:\r\nDon't know how to greace the
Milwaukee K900K or the English Kango 900K Blue old or Red some younger handle it differs very much English Kango was using a thick brown grease in 2 chrome colored plastic bags . the Milwaukee K900K has a lubrication grease also not oil but be aware of the operating hours i f you have a K900K model from Brand Milwaukee tools replace also a service kit and the bearings on the armature is important also Its neccesary to protect you from damage if you have a English Kango its hard and expensive to get a spare parts and most times the tools are worn in the front of the chisel stroke bolds do not get right close and the piston pins are worn it was a good tool about 20 years ago i have serviced much of them . but the first thing thats important that its air-tight in front of the chisel and everywhere thats having a mechanic/pneumatic duty Milwaukee Services and fill k900k with (IMPORTANT) the right number
4/17/2016 1:03:24 PM • Electric... • Answered on Apr 17, 2016
Need to change the brushes
If change brushes it has having its workinghours Use a service kit for your model if there is support for your hammer ??? on EBAY there is a set brushes parts are maybe hard to find for electrical demolition hammer of this brand. Carbon Brushes Chicago electric UL breaker jack hammer NEW 46935 harbor...
4/17/2016 12:39:45 PM • Electric... • Answered on Apr 17, 2016
Baumer ag jack hammer
This is what kind of tools you are missing for to do it without damage some parts by some brands a bearing press .. to press out the gears out of the bearings but beware in some cases there can be uses a forelock and the bearing of the gear can sitting behind a locking ring. allways use the right service manual before decide to. and use safety glasses if using a bearing press 11788989-35lafhp0mk35v0dzukvwn3cr-3-0.jpg
4/17/2016 11:23:08 AM • Electric... • Answered on Apr 17, 2016
Bosch service manual
4/17/2016 11:01:09 AM • Electric... • Answered on Apr 17, 2016
H45sb hitachi moter run but hammer and stop how can i fix it
If pos 22 980-707 is broken it does not function , also if pos 35 is broken 932-815 then also the motor drives but no hammer , also if pos 8 is not moving 987-705 because the lubrication is not good anymore if started leaking and if that happens the piece and all your o-rings will be worn by heating up because thefront ofyour hammer must be air tight all the way , a demolition hammer is made for lasting long hours but leaking although it is still so small its in a few hours inside becomes to hot for the seals o rings and lubrication and then there are Discussions for to get a Service Kit (H 45Sb) - ( 987-712 ) the hammer is to old for economic repair by others some parts are not anymore available, i know it where good hammers , but marketing technical changes in weight, more more speed and less vibrations and for 7 years max parts in stock (not sometimes 15 years as before) and over that time its all discontinued demolition hammers are averaged of use of 6 years by normal usage. Lubrication is not the problem but in front its must airtight otherwise is bad for your arms and shoulders because its build for timing when its airtight. Hitachi H45SB Hammer Parts
4/6/2016 6:09:15 PM • Electric... • Answered on Apr 06, 2016
Brand new and not jacking
if you push the chisel of the hammer on an object the battle piece must become free in the cilinder and must work or something is blocked or wrong intern as it will not work , or the wrong chisel was selled for your machine . remove the chisel and put a long big screwdriver and push it in the locking sleeve as far as possible there must something moved from 2 or about 4 cm depends on the volume of the machine but if nothing moves then go back to your dealerfor warranty.
4/6/2016 5:26:38 PM • Electric... • Answered on Apr 06, 2016
Can not get braker bit out of dewolt hamer
Use a burner to make the work a little bit lighter but wear safety glasses by this job en een leather apron because of the hard metal pieces that can be come of the chisel sometimes if its an heavy machine unmount first the sleeve, from the machine if you have luck to find somebody with a bearing press can make it come loose , but if its handling a little demolition hammer replace the locking sleeve the drill guide is most times worn if you have used the right chisel for your machine.
3/26/2016 12:45:24 PM • Electric... • Answered on Mar 26, 2016
Hitachi hammers and stop hammering while motor still runing
Or a wedge is broken on the drive gear or anchor and drive gear must ALWAYS be replaced together if the teeth are worn.
3/26/2016 12:05:04 PM • Electric... • Answered on Mar 26, 2016
How do I find Instruction manual for Hitachi 1700w electric Jack Hammer
Service Support or google for hitachi hammer and under the choice of images you have chance .
3/26/2016 11:48:43 AM • Electric... • Answered on Mar 26, 2016
Manual for a Makita Electric Jack Hammer
power cable can be fractured, autostop in carbon brushes activated or an loose contact or broken contact in electric field.
3/26/2016 11:43:38 AM • Electric... • Answered on Mar 26, 2016
I have a Hilti Jack Hammer and there is a red wrench light that is on now. The hammer still turns and works but what does it mean.
To service Hilti and Duss are 2 names of expensive professional brands with the highest quality metals and are most delicate brands in the world to service .with high marketing technical developments The technic in these brands are like no other brand , if it has its working hours done , be aware to do this on your own without this knowing that there may be a range of collaborating very special bearings present a coplete collaboration that must be replaced there are special poor-tolerance bearings it likes they where damaged if you feel this parts but its neccesary and very special calculated and the (Hilti )Turmopol oil is also very very expensive and sometimes there are ceramic rings used for the batte piece but in any case costs all a lot of money and its wasted in a very short time if not knowing how to service , if you want to take this yourself, these brands are not toys for Fixya and can harm more than it could happen if you are not aware of the cooperation of the various components in this machines and sometimes hidden tricks to it may be, for example, to release an armature that in a special seal is present which is not just available separately outside of the anchor. So be warned, it does all depend on the model and year out, service on your own without the right tools can make more damage than you may expect
3/25/2016 10:48:07 AM • Electric... • Answered on Mar 25, 2016
2answers
LOOKING FOR A MANUAL & INFO
Milwaukee now owns Kango, unfortunately I believe the 950sv is the old style. Parts are no longer avail. I have about 20 of the breakers. It is really too bad, they were great machines.
3/22/2016 9:06:08 PM • Electric... • Answered on Mar 22, 2016
My Black and Decker demolition jack hammer broke
Go to Dewaltservicenet.com and in the header under service locator follow the prompts and type in your zip code to find the nearest service center near you.
6/12/2015 5:50:35 PM • Electric... • Answered on Jun 12, 2015
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
1/14/2015 8:26:44 PM • Electric... • Answered on Jan 14, 2015
Jack hammer truble shooting
Replace O-Rings? I’m happy to help further over the phone at https://www.6ya.com/expert/jason_60e0f57ba319f3f6
5/9/2014 7:59:57 AM • Electric... • Answered on May 09, 2014
0answers
Will not power on
Be the first to answer 10/6/2013 9:12:45 PM • Electric... • Posted on Oct 06, 2013Be the first to answer
0answers
Electric Demolition Jackhammer Logo
Popular Tags
52 questions posted
Top Electric Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electric Hammering Expert? Answer questions, earn points and help others
View Most Popular
Electric Hammering
  • Electric Hammering
Most Popular Question
kango 900 hammer r ndont know greace
  • Hammering
