20 Most Recent Lisle Serpentine Belt Tool & Accessories - Expanded Model Questions & Answers
Tightening serpentine belt on 2001 P T cruirers
Sounds like the tensioner isn't working. It's easily replaced, but you need a special tool to re install the belt once you have changed tha part
1/25/2014 3:38:02 AM • Lisle Serpentine... • Answered on Jan 25, 2014
Is it my serpentine belt?
It is your AC clutch assembly or AC compressor.
9/11/2013 6:41:35 PM • Lisle Serpentine... • Answered on Sep 11, 2013
Diagram of the serpentine belt on a ford escort zx2
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
The two (2) Links below are for the Escort and the ZX2.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
For the Escort:
http://www.2carpros.com/car_repair_information/year/2000/make/ford/model/escort/2000_ford_escort_drive_belt_routing_diagram.htm
For the ZX2:
http://www.2carpros.com/car_repair_information/year/2000/make/ford/model/zx2/2000_ford_zx2_drive_belt_routing_diagram.htm
8/19/2013 4:43:43 PM • Lisle Serpentine... • Answered on Aug 19, 2013
How to tighten belt on toyota corolla ce 2003
There should be a belt tensioner.
5/19/2013 10:41:33 PM • Lisle Serpentine... • Answered on May 19, 2013
How to bypass the ac pulley by installing a shorter serpentine belt....1996 jetta tdi with siezed compressor.
The air conditioner runs in the winter time when you use the defrost function. This is to dry out the air so that you dont get foggy windows. Dont bypass it.
5/19/2013 10:38:28 PM • Lisle Serpentine... • Answered on May 19, 2013
My serpentine belt broke while driving a 1995 ford escort the car died is this normal
You should be able to replace the belt and be running again. If you ran the engine for a long time or high RPM without the belt, you may have overheated it and caused additional problems - but you'd probably gotten a high temperature warning light if that were the case. The serpentine belt provides a way to transfer mechanical energy from the engine to the alternator, power steering pump, A/C condenser, smog pump, water pump, etc. Once that belt breaks - all of these devices cease to function (even though the engine is still running) and will cause the engine to stop eventually. If you broke a timing belt - that would be a different story - if the engine is an "interference" or a "zero tolerance" type. The valves inside the engine would be crushed by the pistons immediately - rendering the engine in need of some very expensive repairs or complete replacement. Timing belts generally need to be replaced every 50,000 - 60,000 miles (or 5 years - whichever happens first or as outlined in your owner's manual). Engines with timing chains do not require replacement as a regular maintenance item.Good luck!
8/1/2012 9:18:11 PM • Lisle Serpentine... • Answered on Aug 01, 2012
Squeeky belt on a 7.3 powerstroke
have you tried replacing the belt?
3/21/2012 4:12:51 AM • Lisle Serpentine... • Answered on Mar 21, 2012
Belt Diagram serpentine belt Diagram for 1992 Dodge
Only at the dealer or auto shop that payes for the software program.Call the dealer and ask to talk to a tech i work at a ford dealer or i would look it up
11/2/2011 11:46:51 PM • Lisle Serpentine... • Answered on Nov 02, 2011
2answers
Serpentine belt diagram for a 2000 volvo s70
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
3/13/2011 9:51:08 PM • Lisle Serpentine... • Answered on Mar 13, 2011
Please send me a diagrams of how to replace a
It will depend on what engine
Here is a cool pdf of many belt diagrams:
http://onlinemechanical.net/support-files/serpentine_belts.pdf
page 4 of this PDF begins listings of different cars. Find yours and then click on belt number and it will take you to the page for the diagram.
8/18/2010 3:17:23 AM • Lisle Serpentine... • Answered on Aug 18, 2010
Instructions how to replace and adjust serpentine
7/19/2010 4:03:34 AM • Lisle Serpentine... • Answered on Jul 19, 2010
No room under hood to change serpentine belt
Click on the following free direct Link. It has the correct Serpentine Belt Diagrams for your 1998 Pontiac Grand AM depending on your 2.7L Engine Options (AC/No AC etc.).
Let me know if this helped, or if you have additional information questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1998/make/pontiac/model/grand_am/1998_pontiac_grand_am_drive_belt_routing_diagram.htm
"HOW TO":
Standard Rules to Removal the Serpentine Belt with an Automatic Tensioner:
1. Find the Tensioner(s). (See Diagrams on Link)
2. Using a Serpentine Belt Tensioner Tool, Or Wrench OR Ratchet, Rotate/Move the Tensioner USING THE AVAILABLE NUT (on the Pulley or Arm Base) OR the OPENING (3/8ths or 1/2 inch square opening) rotating the Tensioner Pulley/Arm - moving it away from contact with the belt and towards the area where the belt is not in contact with the Tensioner Pulley. The Tensioner is spring loaded, and is hard to rotate/move.
3. Remove the loosened belt off one of the other more easily accessed Pulleys.
4. DO NOT quickly release the Tensioner, but gently allow the Tensioner to rest in its closed position.
Standard Rules for Installing the Serpentine Belt with an Automatic Tensioner:
a. Pick a Pulley that is most easily accessed. This will usually be on top. This will be the last Pulley that the belt will go on.
b. Using the Diagram: Install the new Serpentine Belt on the remainder of the Pulleys....over, under, left right.
c. Using a Serpentine Belt Tensioner Tool or Wrench or Ratchet Tool: Rotate/Move the Tensioner Pulley/Arm "away" from Belt contact area on the Tensioner. This spring is pretty hard and with a new belt, it will be even harder to install. Rotate/Move this to as-close to the maximum allowed inorder to have enough slack in the belt to get it up and over the last pulley.
d. Using your other hand - Pull the Belt up and over the Last remaining Pulley.
e. Before releasing the pressure on the Tensioner, visually inspect the remainder Pulleys and the Belts' Positioning on them
4/2/2010 1:03:45 AM • Lisle Serpentine... • Answered on Apr 02, 2010
What do I need to
For the 1997 Dodge Grand Caravan Serpentine Belt:
Did not specify what Size Engine: 2.4L, 3.0L 3.3L, 3.8L.
Click on the following free direct Link. It has several of the Serpentine Belt Diagrams and Tensioners that are possible with your Size Engine (2.4L, 3.0L, 3.3L, 3.8L) and engine options (AC/No AC, etc.).
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.Com!
http://www.2carpros.com/car_repair_information/year/1997/make/dodge/model/grand_caravan/1997_dodge_grand_caravan_drive_belt_routing_diagram.htm
"HOW TO":
4/1/2010 11:01:06 PM • Lisle Serpentine... • Answered on Apr 01, 2010
How to fix serpentine belt...and where can i purchase one?
"HOW TO":
Standard Rules to Removal the Serpentine Belt with a Tensioner:
Standard Rules for Installing the Serpentine Belt with Tensioners:
4/1/2010 10:52:46 PM • Lisle Serpentine... • Answered on Apr 01, 2010
A diagram for putting on a serepentine belt on a
Click on the following free direct Link. It has the Serpentine Belt Diagrams for your 1998 Jeep Wrangler depending on what engine (2.5.L or 4.0L) and options (AC/No AC etc). Plus additional Instructional and Directional Diagrams.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1998/make/jeep/model/wrangler/1998_jeep_wrangler_drive_belt_routing_diagram.htm
3/29/2010 3:50:29 PM • Lisle Serpentine... • Answered on Mar 29, 2010
I'm trying to put a serpentine belt on a97 buick
there will be a diagram on the radaitor support, or on the hood next to the latch, you will need a wrench to turn the belt tensioner so it will loosen up enought to get the old belt off and the new one on, you have to hold it so you can get the belt off and on.
3/14/2010 1:10:55 AM • Lisle Serpentine... • Answered on Mar 14, 2010
1994 mustang gt serpentine diagram
CLICK
http://www.2carpros.com/car_repair_information/year/1994/make/ford/model/mustang/1994_ford_mustang_drive_belt_routing_diagram.htm
3/8/2010 3:54:14 AM • Lisle Serpentine... • Answered on Mar 08, 2010
CLICK
http://www.2carpros.com/car_repair_information/year/2004/make/dodge/model/pickup/2004_dodge_pickup_drive_belt_routing_diagram.htm
3/8/2010 2:25:44 AM • Lisle Serpentine... • Answered on Mar 08, 2010
Belt diagram
CLICK
3/7/2010 5:58:36 PM • Lisle Serpentine... • Answered on Mar 07, 2010
Lisle Serpentine Belt Tool & Accessories - Expanded Model Logo
67 questions posted
Top Lisle Hammering Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Lisle Hammering Expert? Answer questions, earn points and help others
View Most Popular
Lisle Hammering
  • Lisle Hammering
Most Popular Question
bypass ac pulley installing shorter
  • Hammering
