20 Most Recent
Hayward 100,000 BTU Pool Heater H100ID1 - Above Ground Questions & Answers
Model h100id banging noise when turned on shuts off
VERY low water flow!
Or... No water flow.
This heater as all heaters do, need to have sufficient water flow thru them, or else they Bang like this.
This then creates a problem, for future banging - due to lime up!
The minimal water flow gets so Overheated, that it turns to steam! The steam knocks and pushes the heater around, then the Minerals will precipitate out of the water and forcefully attach to the inside walls of the heat exchanger! Which will then drastically reduce the inner diameter of the exchanger making a much smaller passageway for water to travel thru! This is a major problem to remain this way. It will then need to be dismantled and de-limed to increase the holes once more, and allow a proper water flow.
Hayward h100id heater will not turn on
Could anyone tell me where on the control panel I would find the Diode D1 on the board?
"agreed; it's usually the diode D1 on the board...a 75 cent part"
Pipe boosted are anyone get the same troub
all the warranties are based on the PROPER MAINTENANCE OF WATER CHEMISTRY. if you cannot prove that the water was balanced properly, you will not have a good time passing this through warranty. a severely unbalanced pool can experience this type of failure very quickly.
Heater wont start;don't hear blower motor
there are a variety of causes for this. any one of the safety systems may have detected a fault and thus wont let the heater run. if there is no electricity, the heater wont run. if there is insufficient water flow, the heater wont run.
Hayward heaterh100id won't ignite
Need to be more specific...!
what is it doing?
Is there a pilot?
is it burning?
do you hear any clicking or buzzing?
is it plugged in?
is gas valve on?
is main fuel supply valve open?
is the door on & in place?
It needs tone in place!
