20 Most Recent
Viking VGIC485-6G Gas Kitchen Range Questions & Answers
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
10/31/2021 12:47:02 AM •
Viking...
Answered
on Oct 31, 2021
Viking range burners won't light
from I review I found it might be this...Simple replacement of Glow Bar igniter requires removal of entire front panel with many screws
so sounds like your igniter might be shot - it heats up to ignite the burners - easy fix - get a long torch lighter and just light the gas after turning it on -
11/5/2017 1:32:22 PM •
Viking...
Answered
on Nov 05, 2017
My Viking range is making a gushing noise when the
I have the exact same range and the same problem.
There was also a gas smell that burned my eyes
The whooshing sound is because there is too much pressure in the burner, forcing some of the gas to come out where the orifice goes into the burner. I know this because there was a carbon build up in that location.
It turns out that the oven burner was drilled and then formed into the "u" shape while very hot. That distorted the holes in the burner.
I got a small drill the same size as one of the "good" round holes and re-drilled all the holes in the burner. The only thing to be aware of is the "cross over" holes that go from one side to the other are a little smaller then the main holes that go around the perimeter.
Now there is no smell, no whooshing sound and it works beautifully.
Needless to say, we were very disappointed having spent the extra money for a supposedly "quality" product only to have it perform badly with no service man with any knowledge of the problem.
I went through the whole range just to check it out. I found 22 problems. Mostly small, but things that should not have been allowed to get through quality control. Seems there is very little of that in Vikings Mexico plant.
One thing in particular that was a safety issue (other than the oven burner) was a plastic grommet meant to protect a wire going through some sheet metal. The grommet was too small and was just sitting around the wire instead of locking into the hole in the sheet metal. Thusly, the wire was aloud to "chafe" on the metal where it went through.
I suggest you look very carefully at as much of the range as you can, just to be sure.
Good Luck,
Wade
8/31/2017 4:31:45 PM •
Viking...
Answered
on Aug 31, 2017
Griddle makes backfire noise
I get the same sound but I found it is actually coming from my stainless steel backsplash, it seems like the heat makes it flex from time to time.
9/29/2012 1:37:46 PM •
Viking...
Answered
on Sep 29, 2012
