20 Most Recent Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Questions & Answers
2answers
Errore f6 lavatrice ariston wmg 923
F06: Selector Error Overhaul CND (selector connector) Overhaul Selector Connector Control Selector/CND Continuity Control Selector Motor Replace Selector Replace Card Dado
1/6/2019 5:49:34 PM • Ariston... • Answered on Jan 06, 2019
Ariston dishwasher lkf 720 has a problem on/off, washing and end indicator lights are flashing
Reading the error code The fault on the appliance is signalled via: 1. the continuous rotation of the selector knob 2. the action, for the first 4', of the electrovalve and the drain pump 3. the door becomes unlocked 4. the led flashes: the number of flashes indicates the fault code; the code should be read as follows: · each fast flash (2/3 flashes of the led very close together) represents one code value · the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another · stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes · the procedure is repeated by the appliance cyclically After you determine which the alarm code appeared we will able specifically to help you. Dado
3/1/2018 6:53:14 AM • Ariston... • Answered on Mar 01, 2018
ARISTON MARGHERITA WASHER/DRYER AWD12S The dial
Maybe get a knob type & eliminate this type of problems
11/22/2017 6:42:30 AM • Ariston... • Answered on Nov 22, 2017
2answers
We have an Ariston AVTL 110 Top loading washing
Sounds like the washer control panel has failed.
7/14/2017 3:22:45 PM • Ariston... • Answered on Jul 14, 2017
How to unlock the door
Lamp M flashes slowly when the appliance is switched on and a waiting instructions and at the end of a cycle, indicating that the door can be opened. It flashes quickly when the door should not be opened. A steady light means the appliance has accepted the selected programme. 24967037-ineink0kisfnom0atbkujjcx-3-1.jpg If you correctly use the appliance then defective can be interlock, wiring or board. If the door is constantly locked then you can access to interlock by removing the top cover of washing machine. Dado
10/28/2015 8:29:36 PM • Ariston... • Answered on Oct 28, 2015
HOW TO FIX O9 ERROR CODE?
F09: Machine Setup Error Found (AWD12) Setup error or incompatible EEPROM Control Microprocessor Version Ask for EEPROM Spare Part indicating Microprocessor version Reflash EEPROM Check electronic controller Dado
10/11/2015 6:49:02 PM • Ariston... • Answered on Oct 11, 2015
How do I fit a door bellows seal to ariston front load washer/dryer /
held on with two large clips
4/16/2015 9:54:13 PM • Ariston... • Answered on Apr 16, 2015
Why does my machine fill up with water when it's not switched on?
Sounds like a faulty solenoid valve. Does the water over flow the door and run out onto the floor? The other possibility is that the electronics could be faulty energizing the coil when the machine is off but this is not likely. Do you turn the valves off at the source when you are not using the machine? This would be a simple fix versus going into the machine to find out if the coil is energized or to replace the solenoid valve.
12/4/2014 11:59:40 AM • Ariston... • Answered on Dec 04, 2014
Why does machine not click into stage two after filling up with water. It seems to not want to spin cycle pump still working?
If the drum is not turning, the motor control board is faulty. This may just be a bad solder joint, but you'll need someone with electronics knowledge to check and repair it.
9/14/2014 7:01:05 AM • Ariston... • Answered on Sep 14, 2014
2answers
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
8/30/2014 10:01:30 AM • Ariston... • Answered on Aug 30, 2014
Why my washing machine unable to switch on?
If there are no lights, check the fuse in the plug. If the machine comes on but the drum does not move, the motor control circuit board probably has a burnt connection or bad joint. This may also be the cause of the fuse blowing.
6/6/2014 8:28:46 AM • Ariston... • Answered on Jun 06, 2014
0answers
0answers
Turn off dryer
Be the first to answer 4/14/2014 3:48:59 AM • Ariston... • Posted on Apr 14, 2014Be the first to answer
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
196 questions posted
Top Ariston Technologies Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Andrew
ADMIN Andrew
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Ariston Technologies Washing Machines
Most Popular Question
machine swallow conditioner leaves some
  • Washing Machines
