20 Most Recent
Dodge 2004 Stratus SXT Questions & Answers
04 stratus sxt will not idle
Hi Tom.
It sounds like your IAC, ( Idle Air Control Valve), is not properly controlling the Idle speed of your engine. Try removing the IAC Valve and clean the pintle of carbon build-up. The ECM (Engine Control Module), cannot properly adjust engine Idle if the valve tip has excessive carbon build up on it. If you clean the pintle make sure the tip is less than an inch and an eighth, (1 1/8) from the shoulder to the pintle tip. This is to prevent damage when re-installing it. Retract the spring and spin the pintle inward to set the depth. If this does not work replace the Idle Air Control Valve. Hope this helps.
1994 dodge spirit. Shifted cable
The shift cable on a 1994 Dodge Spirit connects the gear shift lever to the transmission, allowing the driver to shift gears. If the cable is damaged or worn out, it may need to be replaced. Here are the general steps to change the shift cable on a 1994 Dodge Spirit:
- Park the car on a level surface and set the parking brake.
- Locate the shift cable where it connects to the transmission. It will be on the driver's side of the vehicle, near the front of the transmission.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the transmission.
- Trace the cable up to the gear shift lever inside the vehicle.
- Remove any trim pieces or panels that are blocking access to the cable connection at the gear shift lever.
- Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the gear shift lever.
- Remove the old shift cable from the vehicle.
- Install the new shift cable by first attaching it to the gear shift lever and then connecting it to the transmission.
- Secure the cable to the gear shift lever and transmission using the retaining clip or nut that you removed earlier.
- Test the new shift cable by shifting through all of the gears to ensure that it is functioning properly.
- Replace any trim pieces or panels that you removed earlier.
Serpintine belt on 2000 dodge caravan needs attaching
I take it you mean installed. The belt sequence for the pulleys should be on the cross member under the hood over the radiator or somewhere in that vicinity. Follow that pattern and you will have to put a ratchet in the front og the belt tensioner to turn it down far enough to get the belt the rest of the way on. Go to youtube and do a search on how to do it. Someone will have a video showing how to do it.
How to Install YouTube DL.py to Download YouTube Videos to my PC?
Actually, you just need the help of a YouTube Downloader. If you still need help, why not try this YouTube/Video Downloader?
Leawo YouTube Downloader acts far more than a single online video downloader to download YouTube videos and other online videos from various video sharing sites like Facebook, Dailymotion, AOL, iFilm, Myspace, Dailymotion, etc. Besides the ability to download online flash videos, this FLV downloader could also acts as video download accelerator to speed up online video downloading, video accelerator to speed up video buffering for smooth playback, video player to play back videos, and IE browser to browse online videos for free downloading. It could extract audios out of online videos, like converting YouTube video to MP3.
Hope it can be another choice for you or other users. :)
Watch online videos offline freely with Leawo YouTube Downloader
What is digital marketing?
Digital marketing, or “online marketing,” is a form of advertising that uses the internet and digital technologies to connect with customers. Digital marketing seeks to accomplish the same thing as traditional marketing except by leveraging computers, smartphones, and other digital devices rather than traditional media, such as print, radio, or television.
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
