20 Most Recent
HTC Tilt 8900 Smartphone Questions & Answers
Is it possible to use regular headphones on your
If you use an adapter to convert the mini usb connection to headphones you can use it otherwise you will need headphones with the usb plug or a bluetooth set. I find most of my Tilt accessories on EBAY.
It fell down n screen comes white when switch on
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
Can't update dutty rom to
woh guyz ..can u help .guyz ,,
tap the targey firmly and accurately at each location on the screen the target will continue to move until the screen is aligned\\
...add me if you want to help me ..
.yahoomail :
[email protected].facebook :
[email protected]\
.twitter account : enrique_baguio
I forgot my samsung g5620
This process WILL ERASE everything on your phone but will also clear any forgotten passwords:
You can hard reset your tilt by doing the following:
Press and hold down both soft keys (keys with the - symbol on each side of the call buttons)
While doing this....
Press and hold the stylus in the reset switch on the bottom like so:
Enjoy your new password wiped Tilt!
Does the HTC Tilt 8900
Hi there!
Yes the HTC Tilt 8900 has wifi. To turn on the wifi, just follow this steps:
- Open the Wireless Manager (Start > Programs > Wireless Manager)
- Tap the Wi-Fi button to turn on/off the wireless function. (It should be green if the wifi is on and has an X if it's turned off.
- Available wireless networks will be detected
Best regards!
I have an unlock code
i think your phone is locked to your provider. you need to unlock it to use it with other provider, you can unlock it using codes. codes are safe and simpler way in unlocking a phone. i unlocked my phone through codes from this site.
WickedUnlock.com check it out.
Respected sir
i am not able
goto settings-connections-connections (again)- advanced-select networks-edit network (top option)- (if selected)edit current connection-set name( then next)-enter access point name (e.g orange.co.uk) then next-ignore rest of options and select finish.
this worked for my tytn II get onto the three notwork internet, hope this helps for you too.
