20 Most Recent Spectroniq Protron 7'' TFT LCD Portable DVD Questions & Answers
My portable dvd player won't load any dvds anymore
lachallep,
The solution for your problem will be needing a little knowledge with electronic repair and hands on.Most common problem for portable DVD player is their 1) Spindle motor the 2) flex cable ( tin ribbon wire connecting the optic lens and the main board)
note: to check if your spindle motor is working good, you must measure it's resistance and it should be around 200ohms.
For the flexcable all you have to do is check the continuity.
cheers.
mark
2/20/2009 8:18:34 PM • Spectroniq... • Answered on Feb 20, 2009
Spectroniq PDV-768
uk dvds are formatted in PAL
us dvds are NTSC
find your settings screen (usually has a wrench to identify it)
1/1/2009 8:23:37 PM • Spectroniq... • Answered on Jan 01, 2009
I keep getting an error
there is a setting if you can find it, switch it to ntsc or pal to figure out what format the dvd is in/
american made dvds are usually ntsc/
imports are usually pal/
1/1/2009 8:21:08 PM • Spectroniq... • Answered on Jan 01, 2009
Spectroniq pdv 768 region code
  1. Open Device Manager.
  2. Double-click DVD/CD-ROM drives, right-click the DVD drive for which you want to change region settings, and then click Properties.
  3. On the DVD Region tab, make the appropriate changes
cheers
11/8/2008 2:54:03 PM • Spectroniq... • Answered on Nov 08, 2008
I want to update NetFlix. How do I do it please?
Question edited a bit for clarity. All questions need 'make model (what it is)', and we aren't told what type of Spectroniq device you have. I am only seeing portable DVD players and a home theatre system. None of those take Netflix. https://www.google.com/search?q=Spectroniq ..
6/26/2023 4:46:44 PM • Spectroniq... • Answered on Jun 26, 2023
0answers
How to program a spectroniq flat screen color TV 2006 to get channels
go into settings, click tuning, zone ,analog or digital, click start, will download channels if present.
5/4/2018 10:13:44 AM • Spectroniq... • Answered on May 04, 2018
0answers
How to program remote control pltv3250 to spectroniq tv pltv4250 lcd 42
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/ Programming Notes • If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote. • Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality. This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
11/24/2016 12:45:00 AM • Spectroniq... • Answered on Nov 24, 2016
I have a spectroniq PLTV-3250 tv with the picture going out. Sometimes the picture goes out but the sound works. Other times it works great but then goes out again. Where do I begin after I open it.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
8/5/2016 9:45:23 AM • Spectroniq... • Answered on Aug 05, 2016
I DONT HAVE THE REMOTE FOR THIS TV SO IM TRYING TO PROGRAM THE REMOTE
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://electro-medical.blogspot.com/
4/15/2016 4:43:55 PM • Spectroniq... • Answered on Apr 15, 2016
Where can I get a remote control?
Universal remotes can be bought in most electronic stores, Big Department stores or ordered online. See links below. Show your gratitude and press the helpful button and follow me on fixya for more tips and info. https://www.google.ca/aclk?sa=l&ai=Cjk7tPCTFVsfXHYXtpAPMy7aID5T_lccH3PXs6d0C0K3MCQgAEAFg_bCYgegDoAHa4Pj9A8gBAakC77WLpYWDqD6qBCJP0L_6r_44mIPVZ2NdYmgT-qo_YFfZ7QScZX8JG-YfBWNfgAeOn4cCkAcBqAemvhvYBwE&sig=AOD64_0ulvlP98B1rW_jH8OcZd7NFUhpMg&clui=0&q=&ved=0ahUKEwj8ka2hmoDLAhXmtoMKHVpEC_wQ0QwIGQ&adurl=http://clickserve.dartsearch.net/link/click%3Flid%3D43700007524302597%26ds_s_kwgid%3D58700000579323988%26ds_e_adid%3D93733534644%26ds_e_matchtype%3Dsearch%26ds_e_device%3Dc%26ds_e_network%3Dg%26ds_url_v%3D2%26language%3DEN-CA https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&sqi=2&ved=0ahUKEwjctJjmmoDLAhVJlYMKHdugAeIQFggcMAA&url=http%3A%2F%2Fwww.walmart.ca%2Fen&usg=AFQjCNGUg9P_2ah-D9uNan41nmBewXkaAg&bvm=bv.114195076,bs.1,d.amc https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=10&cad=rja&uact=8&sqi=2&ved=0ahUKEwij5pnymoDLAhUouoMKHenjBp8QFghCMAk&url=http%3A%2F%2Fwww.bestbuy.ca%2F&usg=AFQjCNFUFW_nmgr3xSbQPhCvTc9zkBEO-w&bvm=bv.114195076,d.amc https://www.google.ca/aclk?sa=l&ai=COF4JDiXFVoepFImepgPkt4DgBJnnlewHyZzEta0CnsCCBggAEAFg_bCYgegDoAH90sr2A8gBAakC77WLpYWDqD6qBCFP0IIhy12nRo9Vh3eLkjle8Pkiyk5K19ua4uyoZWGbmZaAB7mqrAGQBwGoB6a-G9gHAQ&sig=AOD64_14LskVDI7V3nMtMjHhuBf_finEGw&clui=0&q=&ved=0ahUKEwiq3rSFm4DLAhUBvYMKHeLbB5wQ0QwIGQ&adurl=http://pixel.everesttech.net/4202/cq%3Fev_sid%3D3%26ev_ln%3Dsears%2520outlet%26ev_lx%3Dkwd-12623902%26ev_crx%3D80881039801%26ev_mt%3De%26ev_n%3Dg%26ev_ltx%3D%26ev_pl%3D%26ev_pos%3D1t1%26ev_dvc%3Dc%26ev_dvm%3D%26ev_phy%3D9001059%26ev_loc%3D%26ev_cx%3D161042401%26ev_ax%3D7576498801%26url%3Dhttp://www.sears.ca/outlet%253Fextid%253D250913_ca_1search_2en_3gogl_4outlet_5en-sears-outlet-brands-e_6sears-outlet%2526s_kwcid%253DAL!4202!3!80881039801!e!!g!!sears%252520outlet
2/18/2016 1:57:56 AM • Spectroniq... • Answered on Feb 18, 2016
Dvd I am trying to get the remote control code for a spectroniq pd 1100 dvd player
AMAZONE/EBAY SEARCH FOR PD1100
7/2/2013 9:07:07 PM • Spectroniq... • Answered on Jul 02, 2013
Spectroniq Protron 7'' TFT LCD Portable DVD Logo
9 questions posted
Top Spectroniq Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Spectroniq Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Spectroniq Televison & Video
Most Popular Question
portable dvd player load any dvds
  • Televison & Video
