20 Most Recent Thermador SGS36GS Gas Cooktop Questions & Answers
4answers
I need to replace my Ignitor head on a sgsx365zs
In order to reach the ignitor you must remove the maintop assembly which is one unit and it can be pull up. The rest is very easy under the maintop there are the burners and ignitor so you can replace.
Here is a link so you use as a reference.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110053&diagram_id=192367#d192367
2/2/2022 4:34:11 PM • Thermador... • Answered on Feb 02, 2022
2answers
Thermador Vent Gas Cooktop Model GGCV36 Serial # 89020071
Just google the repair clinic and partselect,they are selling spare parts online..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
3/24/2020 10:26:23 PM • Thermador... • Answered on Mar 24, 2020
Bernzomatic ts 4000 flame adjustment
There is no adjustment on the ts4000. The ts8000 has the ability to adjust by turning the knob while depressed, however the ts4000 does not. If you use a hose with an in-line regulator between the cylinder and the torch that would give you the ability to adjust your flame. Make sure the hose and regulator used are suitable and rated accordingly.
8/20/2018 10:57:20 PM • Thermador... • Answered on Aug 20, 2018
2answers
Burner on Thermador stove top does not light
Switch for burner 4 is not working properly - could have a bad contact resulting in just one spark and nothing more.
5/3/2017 9:43:27 PM • Thermador... • Answered on May 03, 2017
Convert to propane
There is usually a kit which changes the orifice for lp. Call an appliance store to seed if they stick it
10/2/2014 1:20:20 AM • Thermador... • Answered on Oct 02, 2014
No flame on exx low
This is generally due to blocked burner heads due to spills, remove it and clean it thoroughly before going any further.
6/11/2014 11:08:15 AM • Thermador... • Answered on Jun 11, 2014
Burner igniters keep sparking long after the burner is lighted
The igniter is activated by a pressure switch, when you press a button or push in the knob, sounds like it has a bit of gunk in ther e stopping it from coming out again.
5/25/2014 12:33:44 AM • Thermador... • Answered on May 25, 2014
0answers
Frozen locknut on burner Thermador SGSX365ZS
First I would try heating it up until it is red and then twist it off. If that is not an option for you then I would get a rotary tool (hobby size) with a cutoff wheel and carefully cut into it from the side about halfway through. That will get it.
4/9/2014 11:25:11 PM • Thermador... • Answered on Apr 09, 2014
0answers
2answers
Extra low burner that won't ignite
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
12/31/2013 7:55:31 AM • Thermador... • Answered on Dec 31, 2013
0answers
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
8/16/2013 5:59:39 PM • Thermador... • Answered on Aug 16, 2013
Thermador SGS36GS Gas Cooktop Logo
133 questions posted
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
View Most Popular
Thermador Cooktops
  • Thermador Cooktops
Most Popular Question
frozen locknut burner thermador
  • Cooktops
