20 Most Recent
Whirlpool LGR6611L Gas Dryer Questions & Answers
Heat starts and then dies and never goes back on
follow this steps and fix it. God bless you1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped
circuit breakers or blown fuses. An electric dryer uses two circuit
breakers or fuses, and if only one of two is tripped or blown, the dryer
might still run but not heat. Sometimes the power cord disconnects or
burns at the dryer, if this is the case, the wiring and the terminal
block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer
overheats, in which case the dryer will either not run at all or stop
heating. The fuse is usually located on the vent duct, inside the dryer.
A blown fuse will show no continuity when measured with a meter. Before
replacing the fuse, make sure the blower wheel is not broken or
clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gV3bBWAa
10/1/2013 7:24:00 PM •
Whirlpool...
Answered
on Oct 01, 2013
Gas dryer not heating, why?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
12/27/2010 11:40:30 PM •
Whirlpool...
Answered
on Dec 27, 2010
Intermittent heating on my Whirlpool gas dryer
ok have u checked the hi and low relays for continuity these are both found aroundthat area as well and make sure you unplug yr machine before performing this test you also have an ignitor inside the unit which should be drawing 3.3 amps if it is lower then you should replace the ignitor hope this helps
7/18/2010 12:32:25 AM •
Whirlpool...
Answered
on Jul 18, 2010
Dryer wont come on. what should i do?
1. Does the dryer light come on when you open the door? If so, it's likely the belt is broken. You will need to replace the belt.
2. No dryer light? it's likely then that the thermal fuse is blown. They are located in different places on different dryers. On Maytag and many Whirlpool dryers, it is located under the top, right next to the heating element with two white wires leading to it. You can test the fuse by bypassing it TEMPORARILY. If you connect the two wires together or make a jumper for them, (always shut the dryer circuit breaker off FIRST before attempting this) and the dryer magically comes alive (after you turn the circuit breaker back on) then you know what's wrong. Just changing the fuse is often not enough - you should find out why your dryer overheated. (poor airflow - blocked duct, etc)
5/27/2010 6:56:04 AM •
Whirlpool...
Answered
on May 27, 2010
Not sure how to replace the idler slide assembly.
I know it isn't much help but look for wear on the idler arm bracket, it will tell you which way it faces either up or down....then look for wear where the idler arm bracket hooks to the frame of the dryer....also you will look to where the spring attaches to the frame of the dryer when you attach it to the idler arm there will be a slight amount of wear where the spring attaches to the frame....
I will include these two websites for parts and further help:
http://www.partselect.com/http://www.appliancepartspros.com/index.aspxBoth also have chat assistance 24/7.
Good luck,
I hope this helps
11/12/2009 6:39:15 PM •
Whirlpool...
Answered
on Nov 12, 2009
Whirlpool Dryer LGR6611LQ0 will not heat up
there isn't a pilot you have an electroic ignitor in there part number 279311.there also is a sensor,gas coils and the gas valve,you need a meter to read them out,you said you checked the breaker and cleaned lint out ,is it dead?read out the thermal fuse first part number 3392519 located on blower wheel housing,unplug the dryer before you do anything and pull off one of the wires on thermal fuse then read it out hope this helps
11/9/2009 2:22:45 PM •
Whirlpool...
Answered
on Nov 09, 2009
DRUM WILL NOT SPIN, BELT IS OK
have you try to rotate the drum when belt is attached or installed, unplug your machine and try to spin it manualy at the back opening where you can access the mechanical part
try to use the belt when turning it counter-clockwise see if it will turn the drum, if not then the fproblem is the bearing
11/9/2009 2:07:48 PM •
Whirlpool...
Answered
on Nov 09, 2009
Dryer Drum does not spin
SOUNDS LIKE YOU ARE RIGHT. EASIEST WAY TO TELL IS PRY UP THE TOP PANEL. 1ST REMOVE LINT FILTER AND 2 SCREWS BEHIND FILTER ON TOP PANEL.. GET A FLAT BLADE SREWDRIVER AND TOWARD THE FRONT OF THE TOP PANEL THEIR R 2 BLK CLIPS ONE ON EACH SIDE PUSH IN AND THAT SHOULD RELEASE THE CLIPS ONCE YOU GET THE TOP UP. LOOK AT DRIUM IF YOU DONT SEE A BLACK BELT GOING AROUND TUB THEN BELT IS BROKE. PART # 341241 SELLS FR ABOUT 15-28.99. WE STK IT. ITS A VERY COMMON BELT. SHOULD BE ABLE TO GET LOCALLY. IF YOU NEED IT WE HAVE THEM.
allbrandsappliancerepair.com
9/23/2009 2:29:42 AM •
Whirlpool...
Answered
on Sep 23, 2009
LGR6611LQ0
you can but now you have to turn the motor shaft at the belt end..i believe you can put your adjustable behind the plastic square blower wheel shaft..on the motor shaft and try turning with your hand its hard to turn because the drum when turning turns the oppsite way,,im,,here onthejob..use gloves
1/11/2009 5:25:39 PM •
Whirlpool...
Answered
on Jan 11, 2009
How to remove fan from dryer motor LGR6611LQ0
ok corvett your there you just jumped one step..put the motor back and put the 2 motor clips back on,,,ok,,,,now you need to hold the belt side with a tool a grip pliers,,a wrectet head with handle turn which ever tool handle so it will hit the side of the cabnit the right side looking from front,,now wedge that tool..be careful go behind ,,put on worh gloves a must the side of blower wheel housing are sharp..caution got your gloves on,,now turn it to the left not the right,,counter clock wise..onthejob
1/10/2009 12:51:24 AM •
Whirlpool...
Answered
on Jan 10, 2009
Whirlpool WGD4800XQ1 Dryer-- Replaced burner coils and it worked great. The next day no ignition again.
There are about seven different possiblities and the prospective solution in each case appears to be replacement of a different part! I suppose if you have the proper testing equipment for assessing each of those parts, you might be favored with a relatively inexpensive fix. I would be embarassed to suggest you replace all in sequence until the dryer works.
Thermal Fuse: The thermal fuse is a safety mechanism that prevents the dryer from overheating. If it blows, the dryer won't heat. Check if the thermal fuse is intact and replace it if necessary.
Cycling Thermostat: The cycling thermostat regulates the temperature inside the dryer drum. If it's faulty, the dryer may not heat properly. Consider checking and replacing the cycling thermostat.
Igniter: The igniter is responsible for lighting the gas burner. If it's defective, the dryer won't ignite. Inspect the igniter for any signs of damage or malfunction.
Gas Valve Coils: Although you've already replaced them, double-check the gas valve coils. Sometimes, even new parts can fail. Ensure they are securely connected and functioning correctly.
Ventilation: Poor ventilation can lead to longer drying times and affect ignition. Make sure the dryer vent is clean and not obstructed. A clogged vent can cause overheating and affect ignition.
Door Switch: The door switch ensures the dryer doesn't operate when the door is open. If it's faulty, the dryer won't start or heat. Verify that the door switch is functioning properly.
Timer and Controls: Check if the timer advances correctly during the drying cycle. Malfunctioning controls can impact ignition. Inspect the timer and control board for any issues.
Whirlpool Dryer WGD4800XQ1 - OEM Parts & Repair Help - PartSelect.com
On a cabrio whirlpool dryer what does E4 and F4 codes mean
A "F4E4" (Low or No Line Voltage) code indicates there may be a problem with your home power supply, keeping the dryer's heater from turning on. The dryer will continue to run when this diagnostic code is present. Touch any pad to clear the code from the display and return to the estimated time remaining.
