20 Most Recent Epson LX-300+ II Matrix Printer Questions & Answers
Good day, we have a
Make sure the picture is at least as big as the logo to be printed and no lower than 300dpi, there really is no upper limit on quility but these should print OK.
12/6/2018 8:15:12 AM • Epson LX-300+ II... • Answered on Dec 06, 2018
Epson lx series 1(80) download
COMO LO INSTALO EL DRIVER LX SERIES 1 (80)
12/6/2018 8:13:52 AM • Epson LX-300+ II... • Answered on Dec 06, 2018
0answers
Hi there! I would like
Could you possibly print 2 to the page. You may have to change the top margin so it wouldn't take more than half sheet. Just a though. Hope this helps!
9/22/2017 7:50:41 PM • Epson LX-300+ II... • Answered on Sep 22, 2017
2answers
EPSON LX300+II PRINTS THE SMALL FONT & LEFT SIDE
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
6/16/2016 4:00:10 AM • Epson LX-300+ II... • Answered on Jun 16, 2016
Epson Status Monitor 3 :
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
12/18/2015 11:12:21 AM • Epson LX-300+ II... • Answered on Dec 18, 2015
PRINTER PROBLEMS 2 GREEN LIGHTS SIDE BY SIDE KEEP BLINKING. THEN THE PAUSE/ PAPER OUT LIGHTS ONE RED, ONE ORANGE ALSO KEEPS BLINKING. pAPER WONT AUTOMATICALLY FEED
There are several reasons for this problem. One is the paper tray is either too full or not closed properly. There is a sensor and if the sensor is faulty the same symptoms happen. It happened to me sometime back. How old is your printer? If it is within the guarantee period you should take it to the dealer and he will have to either repair or replace it.
11/16/2015 12:11:23 PM • Epson LX-300+ II... • Answered on Nov 16, 2015
Hello guys, how can i change the LX300-ii font spacing. thanks in advance.
You can download user's manual where it explains how to use your printer's control panel to change one of 6 inbuilt fonts. read this short tutorialhttp://maintenanceprinter.blogspot.com/2011/07/how-to-change-fonts-in-epson-lx-300.htmlDownload manual: Descargar Epson LX 300 III guess you can change fonts using control characters but I don't know if you can embad tham in a word doc. No way to test it because I don't have this printer.I remember having done it in early days of DOS word processing with Wordstar.Hold ALT and type the command character - the numbers 27. In notebook will look like an arrow to the left, followed by writing a command character, examples:? P Selects 10 cpi? M Selecting the 12 CPI? ? Select dense Print - 15 CPI (this character is typed by holding the ALT key figures 15)
11/9/2015 3:03:51 AM • Epson LX-300+ II... • Answered on Nov 09, 2015
The dot matrix will print out two invoice sheets before printing out ink on the third one
Replace your ribbon and make sure it's moving. Usually with an impact printer the reason this happens is because the ribbon has stopped spinning.
8/17/2015 5:21:06 PM • Epson LX-300+ II... • Answered on Aug 17, 2015
2answers
HOW TO SET BAUD RATE
HOW TO SET BAUD RATE 9600 OF EPSON LX 300...
1/13/2015 6:11:02 AM • Epson LX-300+ II... • Answered on Jan 13, 2015
Printer head going one side and given beep
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge. 4. Hold the jammed paper with your hands. If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands. 5. Pull the paper slowly not to tear it, then pull the paper out. 6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper. All print jobs in the queue are canceled. Reprint if necessary.
7/21/2014 4:15:19 AM • Epson LX-300+ II... • Answered on Jul 21, 2014
0answers
Epson LX-300+ II Matrix Printer Logo
263 questions posted
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
LX Epson
  • LX Epson
Most Popular Question
  • Office Equipment & Supplies
