20 Most Recent Venta Airwasher Venta LW14 180sq ft Airwasher Air Purifier Questions & Answers
3answers
Water wheels do not turn
Unplug the unit from the A/C outlet.  Turn the fan unit over, and with your finger, spin the fan as fast as you easily can.  Tooth like projections should rotate out of the lower most part of the assembly.  These teeth drive the wheel.  If they don't come out, the problem might be in the seating of that silicon rubber nipple, or the "tooth" assembly could be gummed up with algae and deposits.  You can wash it out.  The problem with mine is the teeth work, but the wheel still doesn't move.  I have emailed the sales office for help.  I love the unit's performance, but it is temperamental.  Good luck, and please post, if you fix it.
8/28/2019 6:36:56 AM • Venta Airwasher... • Answered on Aug 28, 2019
2answers
Can airwasher fan repair during
It will not help purify paint fumes and could be a source of combustion. It is best to ventilate using open windows and positive air pressure from a fan blowing from another room into the fume area. Hope this helps some:)
8/28/2019 6:35:11 AM • Venta Airwasher... • Answered on Aug 28, 2019
2answers
When you add water, you should notice bubbles (just a few) on top of the water.  When the water no longer has bubbles, the additive is shot, and you should wash out the tank.  We have dirty air, and it takes about 2 weeks for us.  I spray it with Murphy's Soap to soak a few minutes and wipe it out with a sponge.  Rinse.   Spray the wheel similarly (all over) and spray with a kitchen hose, as hot as possible.  You may have to repeat.  I clean my wheel between tank cleaning, so it doesn't build up.  You should use the additive, because the water has to be slippery to work with the wheel.  Maybe you can find a different "wetting solution,"  that would be cheaper;  Venta gets an arm and a leg for it.  Good Luck.  I like the performance of mine, but it is temperamental.
8/28/2019 6:31:40 AM • Venta Airwasher... • Answered on Aug 28, 2019
Instruction booklet
It is always a good idea to have owners manual for anything like this on hand has alot of troubleshooting ideas on them.
http://www.venta-airwasher.com/html/customer_service.html
Users Guide
http://www.venta-airwasher.com/html/pdfs/User%20Manual%20AW%2010%20final%2027%20Mar%2006%20venta_AWguide.pdf
11/10/2008 10:24:14 PM • Venta Airwasher... • Answered on Nov 10, 2008
Ionic Pro Platinum TA750 Air Purifier. It will not turn on?
Question edited for clarity and toss in some CAPS. Question moved from Televisions category. Contact their Support for a warranty repair. https://www.envion.com/en/ta750 ..
12/12/2023 5:16:43 AM • Air Purifiers • Answered on Dec 12, 2023
I have an Afloia Air Purifier. The red light keeps blinking?
Question edited for clarity, dreadful spelling and typos. :>D Question moved from Televisions to Air Purifiers. Your air filter is dirty and needs cleaning.
Afloia Air Purifier Blinking Red - Repair, Care and ...
https://plentifulair.com > afloia-air-purifier-blinking-red... A flashing red light in all Afloia air purifiers indicates that the air filter needs to be replaced. Typically, in these air purifiers, the red light turns on ... ‎Why is My Afloia Air Purifier... · ‎How to Replace the Air Filter in... ..
11/7/2023 2:12:50 PM • Air Purifiers • Answered on Nov 07, 2023
Lost remote can I download one or an app for it please.
Question edited for clarity. Question moved from Cars and Trucks. From the maker https://www.google.com/search?q=Fresh+Air+by+Ecoquest+replacement+remote ..
11/7/2023 5:38:27 AM • Air Purifiers • Answered on Nov 07, 2023
My 20w aspectek bug zapper has stopped working, both bulbs off
Turn off the power button and Unplug the bug zapper. Turn off and Unplug Discharge Bent down and Remove Rotate and Replace the bulbs
8/27/2023 12:59:29 PM • Air Purifiers • Answered on Aug 27, 2023
What can I do to troubleshoot fuse blowing each time I turn on sanitizer - Breeze AT by EcoQuest
breaker blows or internal fuse ----either way need a multi meter to test for short
6/20/2023 1:21:36 PM • Air Purifiers • Answered on Jun 20, 2023
Rainmate Air Purifier. Why does my Rainmate not mist?
Question edited for clarity and correct maker name, plus (what it is). Question moved from Cars and Trucks. Usually just need cleaning and descaling
Cleaning Tips
Rainbow System https://rainbowsystem.com > Support You can even fill the Sprayer with ordinary household water and use it to mist your houseplants or clean your screen windows.
The Rainbow Rainmate: Does It Really Work?
GroundWaterGovernance.org https://www.groundwatergovernance.org > does-the-ra... Mar 13, 2022 - The simplest solution appears to be to change the water on a regular basis if possible. A home air purifier can be used as an aromatherapy ...
6/8/2023 3:47:31 PM • Air Purifiers • Answered on Jun 08, 2023
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller. Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device. You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb." If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller. If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need. Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
1/10/2023 4:58:20 PM • Air Purifiers • Answered on Jan 10, 2023
Filter red light flashing. I cleaned filter
Switch it off, count to 50, switch back on. 'make model (what it is)' in all questions, first 3 words please.
11/20/2022 7:31:43 PM • Air Purifiers • Answered on Nov 20, 2022
4answers
Lumipure AP-74 manual needed
hold in the power button for approx 5 seconds
11/4/2022 9:19:34 AM • Air Purifiers • Answered on Nov 04, 2022
5answers
Should I color my hair purple?
The Purple color that you will colored is amazing.Angel Brazilian Virgin Hair Online Store will supply you high quality hair with best price. The hair extension you can buy in our store in purple color.that color is good.A Brazilian weave, also referred to as a Brazilian wave, utilizes 100-percent virgin Brazilian hair to create a soft, wavy style. A stylist can apply Brazilian hair in any weave technique you prefer, allowing you the freedom of choice. However, when a stylist states that she offers a Brazilian weave, she may also be referring to a technique known as the Brazilian knot, where the extension is bound to the hair in small sections using an elastic thread. Taking care of a Brazilian weave is similar to any other human hair weave, but there are a few minor considerations when taking care of Brazilian hair and the Brazilian knot in particular. For details welcome to visit our website www.milkywayhairweft.com www.amazon.com/shops/MoonAngelHair
10/17/2022 11:22:12 AM • Air Purifiers • Answered on Oct 17, 2022
4answers
What is the best method for purifying water?
depends on where you are and when you want the water treated. for camping and hiking , water purification tablets are quick and easy methods and one of the best ( used by the armed forces ) if you want it for home use running the water through a ceramic filter then through an ultra-violet purifier will get rid of all the bugs for larger volumes an osmosis purifying system as used by the water treatment works in council water supplies is best so you need to specific as to when you want the water pure. boiling water is ineffective as it concentrates the bugs and doesn;t kill them all, however distilling water by boiling off and collecting the steam back to water separates the bugs
9/7/2022 11:55:04 AM • Air Purifiers • Answered on Sep 07, 2022
2answers
WINIX 5500-2 4-Stage Air Purifier with PlasmaWave® Technology. I changed the filters but now the white fan light flashing on two fans and won't stop. I did reset.
Resetting Filter Life: After replacing your True HEPA Filter, place the Pre-Filter back in and close the Front Panel. While the unit is on, hold the Filter Reset Button for at least 5 seconds until you hear the beep. After the beep, the Filter Replacement Indicator will disappear. Your Winix True HEPA is now reset you can call (877) 699-4649 for more help
8/31/2022 6:08:44 PM • Air Purifiers • Answered on Aug 31, 2022
My Breathe Fresh, YD-700A, turns ON and ... HIGH, EFFICIENT, STERILIZER and Anion are lit up and will not turn OFF. What does this mean? and is it OK to run in low mode
There is always the possibility that the main control board has failed in that unit. The unit generates very high voltage and negative charges that leave the grid to trap small particles. With that in mind the board can accumulate a static charge and be ruined. Can you run it? I would not. There are cases where units similar to yours have caused fires.
8/23/2022 10:08:01 PM • Air Purifiers • Answered on Aug 23, 2022
Venta Airwasher Venta LW14 180sq ft Airwasher Air Purifier Logo
7 questions posted
Top Venta Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Venta Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
Venta Air Purifiers
  • Venta Air Purifiers
Most Popular Question
instruction booklet
  • Air Purifiers
