20 Most Recent Uniden DECT 6.0 Cordless Telephone Expansion Handset Questions & Answers
5answers
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONSHere is the answer! Press the INTERCOM button one time.The INTERCOM display will show on the screen.Use the UP or DOWN arrow button to select the HANDSET number.Press the MENU/SELECT button to ring the HANDSET selected.Press the END button when done talking
9/7/2022 2:01:15 AM • Uniden DECT 6.0... • Answered on Sep 07, 2022
I have a Panasonic cordless phone, Model KX-TGF350, that we accidentally blocked a important caller how do we unblock this caller?
one if these old land line thing-a-bobs>? LAND LINES:? sure it is. most land lines (gee endless world wide and collapsing) I you actual PHONE has caller ID blocking turn it off, RTM read the manual on your phone. if say using AT&T, land line (wild wild guess) you have special *Number to call and you must reset that using THAT> answered for both ways, and I refuse to read your manual, on any landline-anything, mines CUT CABLE at the CURB.
6/14/2019 12:37:42 PM • Uniden DECT 6.0... • Answered on Jun 14, 2019
Please advise as to how to increase the VOLUME on
To adjust the ringer volume:
  1. With the phone in standby, press ^ or v. The display shows the current volume level and the handset sounds the ringer at that level.
  2. Use ^ to make the ringer volume louder or use v to make it softer or turn it off completely.
  3. When you hear the ringer volume level you want to use, stop pressing keys. The handset will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset won't ring. If you have any accessory handsets, other handsets will ring according to their individual settings.
To adjust the earpiece volume:
You can choose from six volume levels for the handset earpiece. To adjust the earpiece volume while on a call, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the earpiece.
To adjust the speaker volume:
You can choose from six volume levels for the handset speaker while on a speakerphone call. To adjust the handset speaker volume, press ^ to make it louder or v to make it softer. The handset display shows the current volume level for the handset speaker.
Note: The handset earpiece and the handset speaker have separate volume settings.
3/8/2019 2:02:19 AM • Uniden DECT 6.0... • Answered on Mar 08, 2019
My Uniden DECT 6.0 has no dial tone and I cannot
Contact your service provider.
9/25/2018 10:51:50 AM • Uniden DECT 6.0... • Answered on Sep 25, 2018
How do I redial on a uniden dect 6.0 cordless phone
bottom lh black button is redial button just press it and it will dial the last number called
6/28/2018 5:23:58 AM • Uniden DECT 6.0... • Answered on Jun 28, 2018
0answers
0answers
0answers
Phone rings once, but then stops ringing and I can't answer the call
If you have a landline, most likely you have a short in it. Not enough to kill line, but, when the 90 volts a.c. comes in to ring it jumps short. The short answers the phone.. It doesn't stop out going but can cause static. Check the line at the box outside. if bad there call your phone company, if good there, trouble is in house
10/4/2017 9:41:09 PM • Uniden DECT 6.0... • Answered on Oct 04, 2017
0answers
2answers
I have Uniden DECT1480-3.
Up to 6 handsets can be registered with the DECT 1480 phones. I have the 5 phone unit and needed to add the 6th phone. All I got was "Searching" in the display and the battery wouldn't even charge!So here's what you have to do to get additional phones (up to 6 units) to work with the base. If you can get past step 1, it's a snap...Step 1: Place a charged battery in the handset. This could be a problem if all your handsets are not registered, since unregistered phones don't charge (who thought of that design?). What I did was SWAP the battery from an already registered and charged phone with the new unregistered phone.Step 2: Here's where the magic happens. Press the 'END' and '#' keys simultaneously... hold them down until a System Reset menu appears. Select "Deregister HS" and press Menu. Step 3: Now, do the same thing again (hold down END and #), but this time select Base Unavailable and press Menu. You will see Base Unavailable Yes/No... Select Yes. Then place the handset in the base, wait a few seconds, and Voila!. it's registered. You can even change handset numbers using this menu if you play around with it.Thank you, helpful employee at Costco for supplying the magic code. And hey there, UNIDEN... including this in the operation manual would have saved many customers much grief with de-registered phones!Enjoy!
7/17/2017 8:29:24 PM • Uniden DECT 6.0... • Answered on Jul 17, 2017
0answers
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
1,615 questions posted
Top Uniden Lands Phones Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Uniden Lands Phones
  • Uniden Lands Phones
Most Popular Question
use intercom uniden dect 6 0
  • Lands Phones
