20 Most Recent
Maytag M7DH45B2A Dehumidifier Questions & Answers
Humidity sensor
It may be right. Are you sure you need dehumidification?
Put a free-standing humidity meter near the unit to check.
If you still want to run the dehum, take the humidity sensor out of the line and control the unit with a timer.
EHUMIDIFIER RUNS FINE BUT NO WATER IN BUCKET
I had the same problem and went for the s**t or bust option, worked for me.... The pipe that feeds water into the bucket had become 'silted' (clogged up and causing water to flood the floor) so I shoved a pencil up it and wiggled it about. Has been perfect ever since.
Why did it stop condensing water?
The condenser can only remove humidity if there is still humidity in the air. What's your Relative Humidity? A manual sling psychrometer is cheap enough to check it.
