20 Most Recent Avanti WC3201D Wine Cooler Questions & Answers
My Avanti wine cooler is not cooling any more.
piece of junk, can not be fixed. Join all the other ones who have bought this unit.
11/4/2015 4:57:08 PM • Avanti WC3201D... • Answered on Nov 04, 2015
How do I reset the digital conroller on an Avanti
Press and hold both temperature controls until it beeps. It will reset to 50 degrees.
8/20/2012 2:21:42 AM • Avanti WC3201D... • Answered on Aug 20, 2012
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
2/17/2010 10:36:23 PM • Avanti WC3201D... • Answered on Feb 17, 2010
Avanti wc1500dss wine chiller not getting cold but does the opposite gets hot
https://manualsdump.com/en/manuals/avanti-wc1500dss/66172/12 The above has a troubleshooting matrix. Power supply: Check if the wine fridge is receiving power from the mains supply. If it's not, there might be a major issue with the mains power or the PSU circuit board in the product that'll likely need replacing if it's faulty. Condenser fan: The condenser fan is designed to cool the condenser and condenser coil within the Avanti wine cooler. If it doesn't function, the condenser and coil can overheat - causing the internal area of the wine fridge to heat up too. Take a look at the rear of the unit and make sure the condenser fan is spinning freely and not blocked (by dust / dirt) or making excessive noise due debris or a blockage. Thermostat: If the Avanti wine fridge thermostat is working correctly, it's responsible for making the condenser, evaporator, fan, and compressor work - so it's super important! The thermostat also allows you to control and adjust the temperature of the wine cooler so if the reading on thermostat is inaccurate (or flat out wrong) the wine cooler temperature will likely be inaccurate too. Why Is My Avanti Wine Fridge Not Cooling (And How To Fix It) - Expert Wine Storage
10/26/2023 12:56:30 PM • Avanti... • Answered on Oct 26, 2023
Avanti WCR683DZD-2 LED panel blinks when plugged in. Fan or compressor does not come on. Where should I start to begin trying to repair the unit
If your Avanti WCR683DZD-2 wine cooler's LED panel is blinking when plugged in and neither the fan nor the compressor comes on, there could be a few potential issues. Here are some steps you can take to begin troubleshooting and attempting to repair the unit:
  1. Check power supply: Ensure that the wine cooler is receiving power by verifying that the outlet is functioning correctly. Try plugging in another device to confirm if the outlet is working properly.
  2. Inspect the power cord: Examine the power cord for any signs of damage or wear. Make sure it is securely plugged into the wine cooler and the power outlet.
  3. Check the control board: The blinking LED panel suggests a possible issue with the control board. Inspect the control board for any visible signs of damage, such as burnt components or loose connections. If you are knowledgeable about electronics, you can attempt to repair or replace the control board. Otherwise, it may be best to consult a professional technician or contact Avanti for further assistance.
  4. Test the temperature control thermostat: The thermostat controls the operation of the fan and compressor. Using a multimeter, you can check the continuity of the thermostat to determine if it is functioning correctly. If it is faulty, it may need to be replaced.
  5. Examine the compressor: Inspect the compressor for any visible issues, such as loose connections or damaged wires. Ensure that it is receiving power and that the compressor motor is not overheating. If the compressor is not running, it may require professional servicing or replacement.
7/2/2023 2:59:52 PM • Avanti... • Answered on Jul 02, 2023
Avanti EWC1201 wine chiller constantly runs.
This is Thermoelectric Cooler, so no compressor. Clean around the back where the heatsink and fan is. https://www.manuals.ca/avanti/ewc1201/manual?p=9 Customer Service is on the next page. ..
4/14/2023 6:01:30 PM • Avanti... • Answered on Apr 14, 2023
Avanti small fridge freezer temp control?
The single control is what you have to regulate temperature electrically. Variance in temperature is otherwise influenced by how much is contained within (which affects cooling circulation) and how much you keep opening the door. https://settingslab.com/avanti-mini-fridge-settings/
11/22/2022 5:00:26 PM • Avanti... • Answered on Nov 22, 2022
I have an AVANTI model 863 YW refrigerator. Fridge gets too cold and won't shut off. I suspect the thermostat but cannot find a replacement. Thermostat is a RANCO K60-P1102
It is probably a K50. https://www.firstchoice-cs.co.uk/ranco-controls/rnck50-p1102
6/24/2022 6:26:15 PM • Avanti... • Answered on Jun 24, 2022
I have an Avanti BCA280 that won't cool.
The most likely reason for commercial coolers and fridges not cooling is a low gas state. Did you get your gauges out and check the high and low side pressures before you started swapping parts out?
3/2/2022 5:18:08 PM • Avanti... • Answered on Mar 02, 2022
3answers
Cicuit board 0757-83835908
It is a power supply smd 12 volt 6 A model S 126SMD3 it is craft by www.hanny.com.cn
12/26/2021 2:31:26 PM • Avanti... • Answered on Dec 26, 2021
My Avanti chest freezer model cf103 is freezing well but is leaking water
Drain to freezer, defrost and clean
7/29/2021 3:02:56 AM • Avanti... • Answered on Jul 29, 2021
The refrigerator part is not working on our Avanti 3.1, but the freezer part is working. What could be wrong?
Usually the vent at the rear of the freezer is blocked with ice. Often caused by a faulty heater or defrost timer. Also check the circulating fan for the fridge. ..
5/17/2021 11:20:24 PM • Avanti... • Answered on May 17, 2021
My avanti water cooler not working/no power nothing why?
HI David, Please check there: https://manualsbrain.com/en/brands/avanti/fridges/ for a manual. Hope it's helpful
5/17/2021 1:20:37 PM • Avanti... • Answered on May 17, 2021
2answers
Mini fridge. Why did it stop working?
https://www.manualslib.com/manual/792736/Avanti-Rm3306w.html?page=10
1/4/2021 1:01:28 AM • Avanti... • Answered on Jan 04, 2021
Avanti WC3201D Wine Cooler Logo
11 questions posted
Top Avanti Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
vince
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Avanti Refrigerators
Most Popular Question
avanti wine cooler model wc3201d
  • Refrigerators
