20 Most Recent Oreck XL Professional Air Purifier Questions & Answers
3answers
Blinking 'Check Collector Cell' light
which model XL series do you have? There is obviously something shorted or arcing on the plates of the cell. look at the plates and see if they are laying flat and the wires are all still attached across the front of the cell. A loose, sagging, broken or bad contact on the end plates will cause the bad cell lights. clean off the area where the cell makes contact inside the unit. The metal strips that run across the ends of the cell make contact with the plates inside the cell and get their power from them, dirty contacts in any part of these contacts will cause the problem. Even a bad contact from the end cap to the plates inside the cell will cause this. Try wiggling the cell around, kind of push on it on edge to get the plates to shift slightly and clean the points where the plates touch the outer strips on the sides. Check for arcing with the lights turned off,
9/1/2023 8:27:35 PM • Oreck XL... • Answered on Sep 01, 2023
2answers
Red light wont change back to green after cleaning
I did the same thing and now I need to replace the cell collector. You need to replace it to if the wire is broken. Please let me know the outcome of your problem.
Where to find the part is hard to get.
animallover2
11/2/2022 11:47:26 PM • Oreck XL... • Answered on Nov 02, 2022
3answers
Red Light
slow blinking light means the unit is in DRY MODE.. flast blinking light means some sort of arcing or bad power supply.. if in dry mode let the unit run for an hour and it will stop blinking ..
4/23/2022 5:14:51 AM • Oreck XL... • Answered on Apr 23, 2022
I have 2 and both are becoming very noisy!
If you have a oreck store take them in. Thanks for the tip I won't buy any oreck products
4/10/2017 11:06:00 PM • Oreck XL... • Answered on Apr 10, 2017
0answers
2answers
How do i stop the
By changing the Collector Cell. The flashing light is an indication that it needs cleaning.
Here is a link to model you listed above. It has all the information you need, on how to clean the Collector Cell. You can download and print it for future reference.
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Hope this helps you solve the problem.
12/11/2016 12:08:05 PM • Oreck XL... • Answered on Dec 11, 2016
Replacement motor
Did you check out ebay? Google it.
3/3/2016 2:02:08 PM • Oreck XL... • Answered on Mar 03, 2016
A red light flashing with clean filter
bad connection on plates or wires that run along the front of the plates in the cell. If you hear snapping or arcing then its the plates shorting out, look for bent plates and broken wires or loose sagging wires.
11/6/2015 2:27:24 PM • Oreck XL... • Answered on Nov 06, 2015
Oreck SL will not work on medium setting
Either your switch is not making a contact internally or the wire that runs from the motor to the switch is loose or not connected, or that speed is burned out on the motor. Those motors have a separate wire for each speed, so it's either not getting power to the motor from the switch or the that speed setting is burned out on the motor its self. I would just work around it and use the low or high setting until you can take it apart to test if the motor is getting power from the switch, if so then the motor is bad, usually the bearings go out on the motors before the wiring does. Unless your motor was on medium and was stopped for a long period and overheated that setting which will melt the wires and cause it to not work. They have a safety switch on the motors now to keep this from happening.
11/6/2015 2:02:52 PM • Oreck XL... • Answered on Nov 06, 2015
Will not operate, no reaction when power button pressed. All panels properly locked.
first off does the light come on at all? when the switch is moved to the High Medium or low setting do you see a red light or a green light on the right side of the unit? if there is no light at all, then there is either no power and you have a bad cord or a bad outlet. The only other thing could be the switch that needs to be tripped in order to let the unit run, that switch is closed by the front cover locking in place. that switch could be bad or your cover may have the tip of the pin that pushes the switch closed broken off or deformed and not pushing down enough to close the switch. try pushing a screwdriver down on the switch and see if it comes on. There's nothing that can shock you if you push on that switch, the power wires are concealed inside a plastic covered area that the switch slides into. If you close the switch and it doesn't come on the check the power cord or the wall socket for power. See if the cord has any unusual looking spots or lumps, stretching, cuts or anything that looks suspicious.
11/6/2015 1:42:24 PM • Oreck XL... • Answered on Nov 06, 2015
How do I purchase a manual
You might be able to download a manual for free. Just google "Oreck XL Professional Air Purifier manual". Look for one that's free but there will be plenty offers to sell you one. Your other questions will be answered in the manual.
2/3/2015 1:59:06 AM • Oreck XL... • Answered on Feb 03, 2015
How do I put the top on after cleaning a oreck
To put the top back on you have to set in on top about 3/4 of the way before you try sliding it closed. Also check that if you disassembled it to clean the filters some of them will install upside down and then the top will not be able to close.
8/17/2014 12:19:19 PM • Oreck XL... • Answered on Aug 17, 2014
If yours is like mine you need to set the cover on top about 2/3 of the way back and then slide it, if you do not put it there and attempt to slide it it will not work. Play with it a little and it should work for you. Also if you took out some of the filers you can install them upside down and that also will prevent the top from sliding on. Good luck!
8/8/2014 7:01:58 PM • Oreck XL... • Answered on Aug 08, 2014
Take it apart
I had the same issue. What I found upon taking it apart was that it must have fallen and the case was not making contact with one of the safety switches. Taking it apart was easy a mix of phillips head screws and torx screws. Took me 15 minutes to take apart and find the bad spot. I hope your fix is this easy.
8/4/2014 4:50:03 PM • Oreck XL... • Answered on Aug 04, 2014
0answers
0answers
Wont start?
Be the first to answer 7/11/2014 3:30:03 AM • Oreck XL... • Posted on Jul 11, 2014Be the first to answer
Oreck XL Professional Air Purifier Logo
170 questions posted
Top Oreck Air Purifiers Experts
vince
Are you an Oreck Air Purifier Expert? Answer questions, earn points and help others
View Most Popular
Oreck Air Purifiers
  • Oreck Air Purifiers
Most Popular Question
open clean oreck xl air purifier
  • Air Purifiers
