20 Most Recent
Nostalgia Electrics Kegerator Beer Fridge Questions & Answers
Cooling issues
sounds like the thermostat. can you bypass it (ie connect the two wires together) and make it run all the time? If so, replace the thermostat
4/22/2014 9:15:07 PM •
Nostalgia...
Answered
on Apr 22, 2014
Kegerator no longer running cold
You need a new start device if your compressor is not running/pumping.That is the box on the side of the compressor .If you can put your hand on the compressor to make sure it (compressor) is than you have a Freon leak. The small line copper coming off the compressor should be between 75 & approximately 85 if its not ho you have Freon leak somewhere.
11/15/2013 9:18:36 AM •
Nostalgia...
Answered
on Nov 15, 2013
I have an ice maker
Well the problem seems in the Water Inlet Switch, there are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver.
Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit, component units (like the one shown below) usually have exposed gears and don't have holes for test probes.
Thanks
8/21/2009 6:23:23 PM •
Nostalgia...
Answered
on Aug 21, 2009
Russell Hobbs Fridge not working?
Humming is a classic sign that the start / run capacitor for the compressor has failed. Call for service, have it checked for gas and condenser cleaned.
