20 Most Recent
Sound Storm Laboratories SD714MB Car Video Player Questions & Answers
How to show images on screen
Step 1
Turn the device off, wait a few seconds, and then turn it back on again. This process will clear out any software errors that are causing the touchscreen to malfunction. If the touchscreen still doesn't work, remove the device's battery, if possible, wait ten seconds and then put it back in.
Step 2
Remove both the SIM and memory cards from the device, if the device accepts such cards, and then turn the device off and back on again. Sometimes errors in these cards can cause devices to malfunction.
Step 3
Check your device's documentation to see if there is a way to manually recalibrate the screen. This process will either be done through the "Settings" or "Tools" menus, for those devices that have an alternative method of input, or by holding a combination of buttons while you turn the device on, for those devices that only have the touchscreen for input.
Step 4
Upgrade the device's software to the latest version, if possible. Many devices come with software for your computer that will allow you to connect the device and update the software. Often, this process will resolve existing software errors that may be causing the touchscreen to stop responding.
Step 5
Clean the device's contacts and screen using isopropyl alcohol and a small brush. Turn the device off before you clean it.
Step 6
Perform a hard reset as a last resort. This reset will erase everything you have added to the device and return its software and settings to their factory defaults. Even with an unresponsive touchscreen, most devices will have a way to perform this reset either through PC software or by holding a combination of buttons while turning the device on. Consult your device documentation to determine the exact process for performing a hard reset on your device.
Step 7
Contact the manufacturer for your device if the touchscreen is still unresponsive after your troubleshooting attempts. The manufacturer may have additional steps to take that are specific to your device, and if your device is still under warranty you should be able to get a replacement through their customer service division.
Warnings
- If you have the right tools and are willing to risk voiding your warranty, you can also open the device and scrub down the control board using the small brush and isopropyl alcohol.
- Many manufacturers offer free telephone support, but some will charge for the service. Check your product documentation before you contact support to know if you will be charged for the service.
Required Items
- Isopropyl alcohol
- Small brush
References
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
