20 Most Recent AKG Perception Wireless Instrument Set (SR45 PT45 MKG L 14 cable) Questions & Answers
2answers
0answers
0answers
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM • Music • Answered on Feb 07, 2024
2answers
FRONTIOPAE what is this instrument unscrambled
'pianoforte'
1/17/2024 4:22:56 PM • Music • Answered on Jan 17, 2024
Looking for specific screw for a Crate and Barrel table
BREV. N. 838420
1/9/2024 8:32:24 PM • Music • Answered on Jan 09, 2024
I want to manually wire my z-560
1/4/2024 1:18:20 PM • Music • Answered on Jan 04, 2024
Electronic drum
See page 22 troubleshooting of this manual. It may help you. dd501 (yamaha.com)
1/3/2024 2:26:52 PM • Music • Answered on Jan 03, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring. This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM • Music • Answered on Dec 31, 2023
What song did these lyrics come from. (You can set by the water but you just can't drink )
Are you sure you are quoting accurately? Could it be one of these instead? http://www.lyrics.cat/lyrics+lead+a+horse+to+water
12/27/2023 3:43:51 PM • Music • Answered on Dec 27, 2023
Line 6 spider ii head sounds like crap on insane red setting
It's a Line 6 and probably requires a software update from Line 6.
12/24/2023 7:57:43 AM • Music • Answered on Dec 24, 2023
Pricesof yMh PSR 9000 KEYBOARDS
  • Price:$1,099.99 on amazon
11/14/2023 7:53:13 AM • Music • Answered on Nov 14, 2023
Breaking Roland RD 600 hammers
The Roland RD-600 is a digital piano, and its hammer action mechanism is designed to simulate the feel of an acoustic piano. The hammers in digital pianos like the RD-600 are typically made of materials like plastic or a combination of materials to replicate the weighted feel of acoustic piano keys. The breaking of hammers in a digital piano is not a common issue, and it's not typically related to the age of the instrument alone. Several factors could contribute to the breakage of hammers, and it's essential to consider the following possibilities:
  1. Excessive Force: If the keys are played with excessive force or if there's any physical damage to the instrument, it could lead to the breakage of hammers.
  2. Material Quality: The quality of materials used in the construction of the hammers can impact their durability. If the hammers are made from subpar materials, they may be more prone to breaking.
  3. Manufacturing Defects: In some cases, there could be manufacturing defects that make the hammers more susceptible to breakage.
  4. Maintenance: Lack of proper maintenance, such as cleaning and regular inspection, may contribute to the wear and tear of components, including hammers.
If you've observed a pattern of hammers breaking with regularity, it might be worth investigating the specific cause. If it's due to excessive force or physical damage, adjusting playing habits and taking care during transport can help mitigate the issue. As for whether it's worth purchasing new hammers from Roland, it depends on the extent of the damage and the overall condition of the instrument. If the RD-600 is in good condition otherwise and you enjoy playing it, replacing the hammers could be a reasonable option. However, you may want to assess the cost of replacement hammers compared to the overall value of the instrument, factoring in the cost of a used RD-600 and any potential future maintenance needs.
11/12/2023 2:54:05 PM • Music • Answered on Nov 12, 2023
My daughters high school dance team uses a samson 308i speaker/pa system. it is only 6 months old but the music will cut out from one of the speakers. It is not the speaker (we switched them) not th
Few people can afford to combine work and university studies. The only way out for such students is to receive a state scholarship. But how to get it if you are not confident in your abilities? Of course, seek help from a professional scholarship essay writer on essaywriters.org. This service provides services of the best writers who have years of experience in this business. Thanks to them, many students all over the world have already received scholarship. Therefore, do not hesitate, rather turn to this service, because your financial well-being depends only on you.
11/8/2023 4:18:05 PM • Music • Answered on Nov 08, 2023
Looking for age/value of piano. I looked up all the numbers and can't find any matches. Inside the piano is has "A.B. Chase" stamped right in the metal, to the left stamped in black is 103220.
According to the information I found, the serial number 103220 on your piano indicates that it was manufactured between 1910 and 1915
10/28/2023 6:06:06 PM • Music • Answered on Oct 28, 2023
Schematic diagram of behringer gm108 v-tone amp
User Manual V-TONE GM108 (musictribe.com) Following page may help to resolve your issue Behringer V-TONE GM108 Support and Manuals (helpowl.com)
9/18/2023 2:15:23 PM • Music • Answered on Sep 18, 2023
AKG Perception Wireless Instrument Set (SR45 PT45 MKG L 14 cable) Logo
Popular Tags
5 questions posted
Top AKG Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an AKG Music Expert? Answer questions, earn points and help others
View Most Popular
AKG Music
  • AKG Music
Most Popular Question
after 6 months got good service unit
  • Music
