20 Most Recent
EBC Brakes Yellowstuff 4000 High Friction Front Brake Pads Ford F150 4.2L 98-99 Questions & Answers
Why do i not have fire to spark plugs after changing coil pack
If you're not getting fire to the spark plugs after changing the coil pack, it could be due to a few different issues: Faulty new coil pack: It's possible that the new coil pack you installed is faulty or not compatible with your vehicle. Double-check the specifications of the coil pack and make sure it's the correct one for your make and model. Faulty spark plugs: If the spark plugs were not replaced along with the coil pack, they could be worn or damaged and not firing properly. Check the condition of the spark plugs and replace them if necessary. Wiring issues: There could be a problem with the wiring or connections between the coil pack and the spark plugs. Check all of the wiring and connections to make sure they're secure and free of damage or corrosion. Bad ignition control module: The ignition control module (ICM) controls the timing of the spark and sends a signal to the coil pack to fire. If the ICM is faulty, it could prevent the spark plugs from firing. Check the ICM for any signs of damage or wear, and replace it if necessary. Faulty crankshaft position sensor: The crankshaft position sensor tells the computer when to fire the spark plugs. If the sensor is faulty, it could prevent the spark plugs from firing. Check the sensor for any signs of damage or wear, and replace it if necessary. If you've checked all of the above and still can't find the problem, it may be best to take your vehicle to a mechanic or dealership for further diagnosis and repair.
How to unlock it
If your phone has locked you out, the truth is that without the aid of military-grade forensics software, you're going go to have to wipe the phone and reset it back to its original factory settings, clearing all your apps and data along the way. Your phone will be back in the state it was when you first bought it.
12/19/2023 6:54:51 AM •
Cricket
Answered
on Dec 19, 2023
Radiuse of a cricket pitch
The size of the field on which the game is played varies from ground to ground but the pitch is always a rectangular area of 22 yards (20.12 meter) in length and 10ft (3.05 meter) in width.
12/3/2021 12:20:51 PM •
Cricket
Answered
on Dec 03, 2021
What tip of gear do you have to where when you play a Cricket game.
Nowadays it is advisable to have a helmet/face guard, even in social games where batters often can't bat, as there is always one bowler who thinks he is Dale Steyn. You can hire these, and the gear below as well.
A groin box for males, to protect the sensitive bits, was always essential.
Batting gloves, as you can easily be hit on the fingers even by a slow bowler.
Batting pads are advisable, but many people in social games get by with just one, on the front leg.
And of course a bat.
When fielding, only really the wicket-keeper needs special gear, pads and big special gloves. You can't avoid injury when keeping without gloves.
6/25/2018 1:21:35 PM •
Cricket
Answered
on Jun 25, 2018
