20 Most Recent Worldtech Devices GYRO Sky Trooper 35CH Land And Sky Electric RTF RC Helicopter Questions & Answers
2answers
On my grandson's Gyrotor ( new) the charger green
it sounds like your sons battery is bad.
7/29/2017 10:49:05 PM • Worldtech... • Answered on Jul 29, 2017
Can't get my copter to stop spinning no matter how
Looks like you're not the only one with this problem. Four of us have bought one and we're all having the same problem.
Think we've been ripped off.
1/7/2011 11:48:15 AM • Worldtech... • Answered on Jan 07, 2011
My grandson just got and charged his World Tech
yep with super glue
12/25/2010 1:00:37 AM • Worldtech... • Answered on Dec 25, 2010
0answers
Saturn-x 2ch ir helicopter won't turn on
In my case (after a few crashes on Christmas morning) the bottom rotor stopped working, causing the copter to spin around on the ground uncontrolably. I traced the problem to a broken wire which is supposed to connect the motor to the PC board. There are four power wires, two for each motor. The front motor which powers the lower rotor has two wires, black and white. The upper motor is powered by the rear motor which has red and blue power leads. They are all supposed to be connected to four solder connector points laid out in a square pattern at the front, starboard corner of the PC board. In my case the black wire broke at the solder point on the PC board. I don't have a solder gun fine enough or hands steady enough to re-solder the connection so I will be looking for some electronics guy to fix this for me. It should only take a few minutes for someone who does this regularly and we will be airborne again!Hope this helps.Jerry
9/20/2015 6:22:43 PM • Worldtech... • Answered on Sep 20, 2015
Charges and rotors spin...won't lift off
buy an ipad instead
2/25/2014 11:50:17 AM • Worldtech... • Answered on Feb 25, 2014
2answers
Saturn-x 2ch ir helicopter not responding to remote control
What if the red light doesn't stop blinking???
2/25/2014 11:48:55 AM • Worldtech... • Answered on Feb 25, 2014
I bought 2 helicommand voice controlled
I also bought 2 copters on groupon on august and gave to my daughters in this cristhmas but they dont work. It doesnt matter if I charged them all night, the copter does not start. Any ideas? [email protected]
1/14/2014 6:26:21 AM • Worldtech... • Answered on Jan 14, 2014
I bought a World Tech
Try turning the controller power on ( before turning on the chopper) and then quickly moving the left throttle stick up to the fastest setting and then immediately back to the slowest speed setting...The flashing should stop. This calibrates the remote throttle range.
Turn on the helicopter and you should be OK
11/30/2013 4:19:58 PM • Worldtech... • Answered on Nov 30, 2013
Helecopter charging port devective, never would
FixYa is an independent site that is NOT associated with any manufacturer or service provider. It is geared to advise / help people via messaging here; to repair items that are no longer covered under a manufacturer's warranty. FixYa does not sell / provide parts nor does it provide repair persons to perform labor. You should always either return the item to where bought or contact the manufacturer to obtain warranty service first, as many repairs will require opening (or similar work) that will often void a warranty or prevent a store from accepting a return.If you are out of warranty and do not wish to pay to have an item repaired, post the manufacturer's name & model - along with a full description of the problem you're having. The more complete your request is - the more likely ( and sooner) you'll get a reply from someone that may be able to help you get it working again for much less than buying new or sending out for repair. Good luck!
9/9/2013 7:42:31 PM • Worldtech... • Answered on Sep 09, 2013
Worldtech Devices GYRO Sky Trooper 35CH Land And Sky Electric RTF RC Helicopter Logo
13 questions posted
Top Worldtech Devices Toys Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Worldtech Devices Toy Expert? Answer questions, earn points and help others
View Most Popular
  • Worldtech Devices Toys
Most Popular Question
grandsons gyrotor new charger green
  • Toys
